Document: A4, Emergency Procedure After Strong Acceleration (Solution)
Michael II
Post30-04-2002, 22:23    Subject: Document: A4, Emergency Procedure After Strong Acceleration Quote
Audi A4, model years 1997 to 2001
MKB: 1Z, AHU, AFN, AFB, AJM, AKN, AHH, AGR, ATJ, AFF, AVG
Symptoms:
Engine stalls after heavy acceleration, EPC light is on, error code 18047 or 00777, "Gas pedal position sensor - implausible signal".
Causes:
In the case of the gas pedal position sensor, increased wear of the potentiometer track can lead to an insulating coating with occasional voltage drops. In the event of failure, the gasoline engine reduces its torque by 50%, and the diesel engine switches to a reduced operating speed of 1500 rpm. After turning the ignition off and on, the intermittent fault is reset, and the vehicle regains its full engine power.
Solution:
Partial Replacement. Affected is only the pedal module from the company Hella.
Tschüss
Michael II
Ratings - Document: A4, Emergency Procedure After Strong Acceleration
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 1 - View ratings
No new posts A4 Doku: Emergency Mode After Heavy Load (KW 09/1999) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Touareg, Transmission in Emergency Mode Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AXR starker Leistungsverlust nach ZKD Wechsel Diesel Engine Technology
No new posts TDI Cold Start: Emergency Mode Troubleshooting On-Board Diagnostics (OBD)
No new posts Cold Start Problems? Emergency Mode Explained. Diesel Engine Technology
No new posts Emergency mode after disconnecting EGR valve on a 2.0 DTI... Diesel Engine Technology
