MWB16 & LiMa Replacement: Questions & Answers
polo2f
Post12-02-2007, 21:38    Subject: MWB16 & LiMa Replacement: Questions & Answers Quote
Hello.
I retrofitted the glow plug heating system to my ALH engine. Now I have a 120A alternator lying around that I want to install in my car. Currently, I have a 90A alternator installed.
In the MWB 16 diagnostic data from the engine control unit, the alternator load is displayed as a percentage.
1. How is this value calculated?
2. Does the STG (Steuergerät - control unit) automatically recognize that the new alternator (LiMa) has more capabilities, or do I need to reprogram (recode) the STG?
3. The first screw-on fuse on the battery, from the left, is 110A. The car from which I removed the starter/generator had a 120A alternator, and that fuse was 150A. Should I also install the 150A fuse, or should I leave the 110A fuse in place?
Paul.
Translated on 31-10-2026, 0:19.
Post12-02-2007, 22:15    Subject: MWB16 & LiMa Replacement: Questions & Answers Quote
Okay, just think about what the fuse would do if the alternator was delivering its full power of 120 amps with a 110 amp fuse... It would probably cause a spectacular short circuit... greetings.
Translated on 31-10-2026, 0:20.
polo2f
Post12-02-2007, 22:43    Subject: MWB16 & LiMa Replacement: Questions & Answers Quote
'That's why I'm asking. Theoretically, I would also have to replace the cable, or is it the same for all models? And whether the alternator ever has to deliver the full 120A is another question...'
Translated on 31-10-2026, 0:21.
Holger247
Post13-02-2007, 9:42    Subject: MWB16 & LiMa Replacement: Questions & Answers Quote
I have no idea if the connection is the same. That will probably only be revealed by looking in the parts catalog.
Here's the translation:
"Another question: You retrofitted the glow plug heater to the ALH engine - wasn't that a standard feature? Which vehicle are we talking about? Was it an import from a tropical country?"
GIV - 98 - ALH
Touran 5T 2.0 TDI
Translated on 31-10-2026, 0:22.
polo2f
Post13-02-2007, 20:16    Subject: MWB16 & LiMa Replacement: Questions & Answers Quote
hello
It's a 1999 Bora with an ALH engine.
It wasn't included because it had an automatic transmission. Automatic vehicles (Golf 4 Bora) never had glow plug preheating. At least, that's the case with VEP models. I'm not sure how it is with Rümpeldüse engines.
'For this, the automatic cars had an exhaust-water heat exchanger that was heated by the exhaust flow from the EGR system. Since I've now converted to a 6-speed transmission and have an exhaust temperature sensor instead of the EGR system, I've retrofitted a GKH (gas recirculation heat exchanger).'
Paul.
Translated on 31-10-2026, 0:23.
No new posts ZR Replacement: Additional Work & Costs Diesel Engine Technology
No new posts LiMA Defect? How to Check Correctly. Diesel Engine Technology
No new posts LIMA Clutch Part Number: ina e227 628 4 61 Transmission, Chassis, Body & Interior
No new posts Golf3 TD, Valea LiMa excitation current missing Electrical Systems, Vehicle Electronics, Multimedia
