Marco wrote: |
"When the steering is fully turned or when driving over a bump, there's a cracking sound coming from the front of the suspension. It sounds like something is strained or under pressure."
2. When I accelerate, the car pulls to the left. However, this only happens when accelerating. When driving at a constant speed, the car runs straight perfectly well. |
Hello Marco,
Park your car on a level surface, make sure no gear is engaged, and firmly apply the parking brake.
Then, use a wheel nut wrench to try and turn the right and left front wheels without loosening the nuts.
If necessary, tighten the motherboard a little more.
If the front wheel moves forward and backward (even a movement of more than 5 mm is enough to cause the car to pull to one side), you need to find the loose part of the suspension system.
Since I don't know about your bike's suspension system, I can't give you any further advice on that.
For understanding: when accelerating, the front wheels are pushed forward. If one wheel is pushed further forward than the other, depending on the geometry/design of the tie rods, this causes a slightly different "straight-ahead" alignment of the wheels to the left or right, meaning they are not mirror images of each other.
The cracking sounds can also indicate loose parts in the wheel suspension.
In theory, wheel bearings that are slightly loose within the housing could also cause a cracking sound when the steering is fully locked, which would not be a major issue. However, I have never personally experienced this; all the wheel bearings were very tightly fitted in their housings.
Damaged constant velocity joints can also make a clicking noise, but they don't explain why your car is pulling to the left.
