02-03-2007, 15:53 Subject: Valve Stem Cap Keys: Remove & Replace |
Hi.
I don't remember if it was on a Vectra B or a Seat, but it had some kind of extension for valve caps in the fuel filler door.
It was a gray plastic tube that you could insert the valve caps into, which made it easier to screw them on.
I'm currently struggling to remove the hubcaps on my Passat. They're so deeply recessed within the wheel covers that I can't get to them.
Is this extension also available individually from VW, or somewhere else?
Greetings.
Translated on 18-10-2026, 14:17.
Profile PM Garage |
Roger Profi-Schrauber
Joined: 10/11/2002 Posts: 3035 Karma: +88 / -0 Location: Rodgau 2017 Volkswagen Golf Premium Support
02-03-2007, 16:01 Subject: Valve Stem Cap Keys: Remove & Replace |
"Doesn't every VW already have that from the factory?"
Nothing more will be unscrewed for inspection; you can find the relevant information under "Extension" or a similar heading in the documentation.
Translated on 18-10-2026, 14:18.
Profile PM Garage |
matthiasTDI96 Profi-Schrauber
02-03-2007, 16:04 Subject: Valve Stem Cap Keys: Remove & Replace |
No... did they save on those for the 3C...? Aren't they on every valve?
Translated on 18-10-2026, 14:19.
02-03-2007, 16:18 Subject: Valve Stem Cap Keys: Remove & Replace |
What the document says looks like a "long valve cap."
"I have those. I also had 4 of them lying around from my old Leon, but I can't find them anymore."
My Zafira B colleague just confirmed that Opel has a dedicated extension key that clips into the fuel filler door.
I need this tool because, despite the longer valve caps, I can't reach the valve stems on the wheel covers of the 3C model.
Profile PM Garage |
03-03-2007, 16:53 Subject: Valve Stem Cap Keys: Remove & Replace |
This is what I meant.
Every Opel has it, it's obvious.
| Description: |
| File size: |
28.81 KB |
| Viewed: |
3153 times |
Translated on 18-10-2026, 14:20.
Profile PM Garage |
bloesch Profi-Schrauber
Joined: 03/18/2005 Posts: 622 Karma: +16 / -0 Location: FL
03-03-2007, 17:00 Subject: Valve Stem Cap Keys: Remove & Replace |
It also seems to serve the additional purpose of enabling or disabling the child lock.
Did you buy that thing?
How much does it cost?  I also don't always feel like bending my fingers and getting them dirty. }
Translated on 18-10-2026, 14:21.
03-03-2007, 17:13 Subject: Valve Stem Cap Keys: Remove & Replace |
My Zafira colleague lent me the part, and it fits perfectly.
I now have several options:
- to steal a part from my dad's Vectra  .
- Nagging my dad about how he doesn't need that (which is probably true).
- To have a heated discussion with another Opel driver.
- order from Opel
Let's see, the next time I'm near the Vectra  .
Translated on 18-10-2026, 14:22.
Profile PM Garage |
tdi pumpe düse Guest
04-03-2007, 19:11 Subject: Valve Stem Cap Keys: Remove & Replace |
Hello Martin,
Go to a tire shop and buy the valve extensions with part number 3B0 601 373A. You simply screw them onto the valve. You won't need to unscrew the cap to check the tire pressure, it's that easy. You'll need to do this for all four tires, since you have four tires, haha.
I can only recommend these things, and you won't get your hands dirty.
But be careful, these parts are in high demand and are often stolen. I actually had to buy some just recently because someone had stolen mine.
If you've ever tried these products and maybe even bought some, please share your opinion about them.
Translated on 18-10-2026, 14:23.
haithamina Schrauber
Joined: 05/15/2006 Posts: 666 Karma: +27 / -3 Location: 69221 Dossenheim
05-03-2007, 14:13 Subject: Valve Stem Cap Keys: Remove & Replace |
Yes, the valve caps recommended by my predecessor are very good. The only disadvantage, besides the risk of loosening, is that air pressure gauges that are placed on them and are supposed to stay in place (e.g., those with two digital displays at Aral) don't stay on. These require the threads of the valve to stay in place. Therefore, the described caps are particularly useful for portable devices that you take with you to every bike and attach to a connection on the compressed air system for inflating. So, the ones with the large analog display. - haithamina
Translated on 18-10-2026, 14:24.
05-03-2007, 15:31 Subject: Valve Stem Cap Keys: Remove & Replace |
dieselmartin wrote: | What the file says looks like a "long valve cap".
Is that not 3B0 601 373A?
Translated on 18-10-2026, 14:25.
LZ Blaumann
Joined: 09/01/2003 Posts: 218 Karma: +6 / -0 Location: .at-Klbg.
08-03-2007, 1:03 Subject: Valve Stem Cap Keys: Remove & Replace |
A piece of silicone tubing also works quite well – simply choose an inner diameter that fits the valve cap. This is an old trick from the automotive electrical trade: it was the only way to get the instrument panel light bulbs out back in the day...
Best regards, Robert.
Translated on 18-10-2026, 14:26.
