Octavia Control Unit: Buy Online Now!
volkersi
Post04-07-2006, 17:37    Subject: Octavia Control Unit: Buy Online Now! Quote
Hello, I have a request as a complete beginner: I need some information about the following control unit: 1 CO 959799 A. I assume it is for the central locking system? It has three connectors, one of which is not connected (15-pin). Can this device be used to retrofit a remote control system, and if so, how? Vehicle: Skoda Octavia Combi, manufactured in 1/2002, 90 HP, 1.9 liters. Looking forward to hearing from you. Best regards from the beginner icon_biggrin.gif
Translated on 08-09-2026, 13:20.
Ross-Tech-Support
Post04-07-2006, 20:17    Subject: Octavia Control Unit: Buy Online Now! Quote
The part number is incomplete; it's missing the index/color code that reveals the exact details about the control unit. Furthermore, it's questionable which control unit is currently installed and whether the production periods align.
Translated on 08-09-2026, 13:21.
danko
Post04-07-2006, 20:29    Subject: Octavia Control Unit: Buy Online Now! Quote
Hi!
I couldn't find the part number 1 CO 959799 in the parts catalog, and I believe the number might be incomplete. However, none of the control units listed under 1 CO 959799 have the note "for vehicles with FFB" included. That note only appears for the 1J0 959 799 AH control units. I suspect you need one from this series for retrofitting the original FFB (likely the 1J0 959 799 AH 05N). However, it only costs 192 EUR.
CU Danko.
Skoda Octavia 1.9 TDI Elegance MJ2002
VP TDI 81kW (MKB ASV)
Translated on 08-09-2026, 13:22.
Ross-Tech-Support
Post04-07-2006, 20:31    Subject: Octavia Control Unit: Buy Online Now! Quote
The part number 1C0-959-799-A is correct, but as mentioned, the index/color code is missing. Please note that there is no letter "O" (Ohhhh) in the part numbers, only the number "0" (zero).
P.S.: 1C0-959-799-A is also available with FFB. icon_wink.gif
Translated on 08-09-2026, 13:23.
volkersi
Post04-07-2006, 21:49    Subject: Octavia Control Unit: Buy Online Now! Quote
Thank you in advance to everyone, you are all really very fast. Because of the missing number, I will try again tomorrow icon_biggrin.gif and I will get back to you afterwards. Best regards.
danko
Post04-07-2006, 23:03    Subject: Octavia Control Unit: Buy Online Now! Quote
Okay, I found it now too.
Wow! There are at least 30 different versions of "central control units" available.
"comfort system".
At first glance, it appears that only the 04H and 04J variants are not designed for Force Feedback (FFB).
CU Danko.
Translated on 08-09-2026, 13:24.
Ross-Tech-Support
Post04-07-2006, 23:18    Subject: Octavia Control Unit: Buy Online Now! Quote
danko wrote:
Man, man!!! There are at least 30 different versions of "central control units for comfort systems" available.
According to the latest count, there are over 250 affected units, as the control unit is installed in numerous models. Without a correct index, it will be difficult to determine the exact number.
Translated on 08-09-2026, 13:25.
volkersi
Post06-07-2006, 13:29    Subject: Octavia Control Unit: Buy Online Now! Quote
Okay, I just came out of the Octo with a lot of numbers icon_eek.gif. I noted down the following combination: ZM midi max 5 DK 008 213-00 III 44601: H01/S0003. The device is from Hella, model HLO? Thanks in advance, greetings from the newbie.
Ross-Tech-Support
Post09-07-2006, 18:52    Subject: Octavia Control Unit: Buy Online Now! Quote
Even the incorrect ones... read them through the diagnostic tool, that's the only way to know for sure...
Translated on 08-09-2026, 13:26.
volkersi
Post18-01-2007, 14:18    Subject: Octavia Control Unit: Buy Online Now! Quote
Okay, here I am again. I was at the mechanic yesterday to get some things done, including the TÜV inspection icon_sad.gif. In that process, I requested and received the data from the comfort control unit icon_biggrin.gif. Here's what was printed: Comfort system - door control unit (TSG) front.
1CO959799A
4H Comfort Device HLO 0003.
Coding 67.
Company registration number 31480.
1U4959801D
4H Door Controller. FS KLO 0002.
1U4959802D
4H Türsteuer. BF KLO 0002
Okay, here's the translation:
"Now, my question again: Is it possible to retrofit a radio-based locking system to this device, and if so, how? Thank you in advance for your answers. Best regards from a newbie."
Translated on 08-09-2026, 13:27.
Ross-Tech-Support
Post18-01-2007, 14:41    Subject: Octavia Control Unit: Buy Online Now! Quote
volkersi wrote:
Is it possible to retrofit a radio-based locking system to the device, and if so, how?
No, this control unit (part number 1C0-959-799-A-04H) does not support that feature.
Translated on 08-09-2026, 13:29.
volkersi
Post18-01-2007, 21:49    Subject: Octavia Control Unit: Buy Online Now! Quote
So far, so good icon_sad.gif. Now, I need information on the options for implementing a feedback system. Can you easily purchase a suitable control unit for this (from the VAG group?) icon_question.gif And what would the cost be icon_wink.gif? You can certainly provide me with the corresponding part numbers }. Thanks again, and I commend you for your expertise and speed. Best regards, Volker.
volkersi
Post09-03-2007, 21:06    Subject: Octavia Control Unit: Buy Online Now! Quote
"Here I am again, I just found an engine control unit on eBay with the part number 1c0 959 799 B/ 00J. According to the seller's description, it's suitable for FFB (presumably a type of steering wheel). My question to you is: Can I use this unit? And if so, what key(s) do I need for it (part number?) Thank you in advance for a quick answer (the eBay listing ends tomorrow afternoon)."
Greetings from the newbie.
Translated on 08-09-2026, 13:30.
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Golf IV / Octavia 1 Water ingress at the doors Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts Log BKD Octavia 2.0 TDI Upload
No new posts VW UHV Low Install in Octavia 1Z Transmission, Chassis, Body & Interior
No new posts Skoda Octavia 1.9: Specs, Problems, & More On-Board Diagnostics (OBD)
No new posts Octavia 1U 1.8T power fluctuation Gasoline Engine Technology
