Passat/Superb: Accessing Engine Bay from Interior
Georg_G
2012 Volkswagen Golf
Post13-02-2011, 16:36    Subject: Passat/Superb: Accessing Engine Bay from Interior Quote
It's about a Škoda Superb I, manufactured in 2008, which is largely identical to the Volkswagen Passat 3BG.
I'm looking for a way to route a thin hose for my boost gauge from the interior of the car to the engine compartment. I've already tried searching on my own:
Ich habe die Verkleidung unterhalb des Lenkrades abgenommen. Dort habe ich aber auch nach längerer Suche keinen Blindstopfen o. A. seen.
There has to be a way to reach the engine control unit along the cable harness. But it's so complicatedly installed; there must be an easier solution!
Does anyone have a tip for me?
Best regards, Georg.
Translated on 06-08-2026, 12:10.
voodoo
Georg_G likes this.
Post14-02-2011, 9:44    Subject: Passat/Superb: Accessing Engine Bay from Interior Quote
From the water reservoir compartment (where the MSG is located), it's possible to pass cables through the existing cable guides and into the splash guard.
You exit from below the fuse box.
Stefan
Translated on 06-08-2026, 12:11.
scrdel
Karma: +4 / -2   Thank you, like it!
2002 Volkswagen Passat
Post14-02-2011, 19:52    Subject: Passat/Superb: Accessing Engine Bay from Interior Quote
Hey, or try folding back the carpet under the pedals; from there, you can also get past the splash guard.
Sven.
Georg_G
Post15-02-2011, 9:16    Subject: Passat/Superb: Accessing Engine Bay from Interior Quote
Hello.
Voodoo, thank you for the reply.
I had hoped there might be another way, but I suppose I'll have to do it this way after all.
scrdel, Unfortunately, I couldn't find a blind plug under the carpet.
Translated on 06-08-2026, 12:12.
scrdel
Post15-02-2011, 20:09    Subject: Passat/Superb: Accessing Engine Bay from Interior Quote
Hi, doch doch da ist eine Durchführung, zumindest bei mir, da hab ich meine Strippen für die Standheizung durchgelegt. Die liegt in der Nähe des bei mir nicht vorhandenem Kupplungspedals. ScOkay, go ahead.
https://community.dieselschrauber.org/en/viewtopic.php?t=20126
I wrote that before; you can see there where the wires come out in the footwell and where they go into the motor.
Best regards, Sven.
Translated on 06-08-2026, 12:13.
Georg_G
Post18-02-2011, 21:48    Subject: Passat/Superb: Accessing Engine Bay from Interior Quote
Feedback again:
The cable conduits in the footwell are also available, as described by scrdel.
However, routing the charge air cooler hose through the motor control unit housing is a much better option than running it through the water reservoir.
Here's a tip: When looking at the car from the front, the rearmost screw of the plastic cover on the MSG (Modular Service Gateway) box, located under the windshield wiper arm, can be loosened from above through a plug in the wiper arm.
This plug is extremely difficult to see, but it's well-made and fits perfectly icon_smile.gif.
You need a 1/4" 8mm socket with an extension. A 3/8" socket is already too thick for the hole in the deflector.
Thank you for your feedback.
George.
Translated on 06-08-2026, 12:14.
No new posts Passat 3C or Superb 3T emergency unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dry the interior General Tips
No new posts Exhaust fumes inside the cabin, VW T6 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Engine Bay to Interior Pass-Through Diesel Engine Technology
No new posts Tip: Dampy interior, Passat 3B Transmission, Chassis, Body & Interior
No new posts Exhaust Fumes in Car: Causes & Solutions Transmission, Chassis, Body & Interior
No new posts Plastic Adhesive for Interior Car Parts Transmission, Chassis, Body & Interior
