Fuel Injection Quantity Sensor Audi 80 B4 1Z
audi80
Post22-04-2007, 12:30    Subject: Fuel Injection Quantity Sensor Audi 80 B4 1Z Quote
Hello!
It's me again!
Subject: Control Unit: 8A0 001 401 B
What value is displayed in field 4 for the injection quantity? Is this the actual value, calculated from the signal received from the engine control unit (ECU) and adjusted based on factors like fuel temperature, or is it the target value, a calculated value dependent on the driver's desired performance within torque and emissions limits?
Here's another way to ask:
Is the signaling system being adjusted to this value (i.e., the setpoint), or is this the corrected/converted value that is reported by the signaling system (i.e., the actual value)?
"I'm also looking for a comprehensive list of all possible diagnostic codes, specifically categorized by vehicle type (VE) and production date (PD), regardless of the engine code (MKB). I think I saw such a list somewhere before, but I can't find it anymore. If anyone could be so kind as to provide me with a link to it, that would be great."
And another piece of information for everyone with the aforementioned engine control unit (ECU):
EMW:
Channel | Value
00 Accelerator pedal
01 P. Environment.
06 RWG Poti (instead of the fixed RWG setting on HDK pumps --> for adjustment after seal replacement).
07 LMengenM Poti
08 V = STG
09 Signal needle stroke.
65 T. Intake.
66 Water level filter.
67 T. Diesel ESP.
68. Coolant water.
69 Intake air temperature.
72 P. Intake manifold.
Has anyone else found any more (useful) ones, just out of curiosity?
Thank you.
George.
Translated on 03-08-2026, 11:44.
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts Audi A6 2.5 TDI AKE Quattro fuel injection quantity Diesel Engine Technology
No new posts MWB 032 Feld 2 On-Board Diagnostics (OBD)
No new posts EDC16 Data Block 9: Field 4 Explained Diesel Engine Technology
No new posts Messwert Block 9 Feld 3 Diesel Engine Technology
