Air conditioning not working - Passat, 1997
chli1976
Karma: +185 / -0   Thank you, like it!
Post23-04-2007, 8:31    Subject: Air conditioning not working - Passat, 1997 Quote
Hello.
"My climate control (Climatronic) has stopped working recently."
I have connected a service station, and the pressure on the low-pressure side reaches the target value of 2 bar after the magnetic coupling is activated. However, the high-pressure side does not increase from the static pressure of approximately 4 bar at an ambient temperature of 15°C; instead, it drops to 2 bar.
After that, I extracted the refrigerant (approximately 900 grams). The suction process didn't proceed normally; instead, after the service station entered the vacuum range and the suction stopped, the pressure in both circuits increased again (almost to the static pressure of 4 bar).
This continued for over 2 hours. (Possible moisture in the system?)
After that, I removed the expansion valve and compared it to another one. The openings of the control piston matched the new valve.
I then detached the hoses from the compressor and manually rotated the compressor. On the pressure side, I was able to build up some pressure. However, I still removed the cover from the compressor and examined the valves. These are also fine, and they don't contain any wood shavings.
I then flushed the pipes again, and I couldn't detect any blockage.
I'm going to replace the dryer now, because I've run out of ideas, and hope that it will then work.
chli1976
Post27-04-2007, 21:58    Subject: Air conditioning not working - Passat, 1997 Quote
Today I installed a new dryer, evacuated it for 30 minutes, and then refilled it.
Suction pressure drops to approximately 2 bar, high pressure is around 6 bar, and the exhaust temperature is approximately 9 °C.
No new posts Touran GRA not working after TCU replacement Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3C air conditioning not cooling General Tips
No new posts Audi A3 TDI AC Fan - 1st Speed Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts GRA im Passat 3B 1999 funktioniert nicht On-Board Diagnostics (OBD)
No new posts Cruise control not working Diesel Engine Technology
No new posts ABS/EDS Error: Troubleshooting & Fixes On-Board Diagnostics (OBD)
No new posts GRA Activation Not Working? Troubleshooting Guide. Diesel Engine Technology
