VW Passat: Adjusting the Accelerator Pedal
jenseden
Post30-11-2002, 16:17    Subject: VW Passat: Adjusting the Accelerator Pedal Quote
Hello everyone,
I've used VAG-COM and discovered that the throttle pedal on my Passat 3B is set to a very 'late' position, meaning that 100% throttle is only reached when the pedal touches the floor. If I release the pedal by just 1 mm, the value jumps to 98.8%. I would like to adjust the pedal so that 100% is reached earlier. Is there a way to adjust this (e.g., with an adjustment screw)?
Can I actually shorten the pedal stroke? (It seems very long to me).
'Thank you very much!'
Translated on 19-10-2026, 9:48.
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adjust Gas Pedal: How-to Guide & Tips Diesel Engine Technology
No new posts Passat 3B Rear Axle Alignment Guide Transmission, Chassis, Body & Interior
No new posts Accelerator characteristics AHF Electrical Systems, Vehicle Electronics, Multimedia
No new posts Sharan AUY Gas Pedal Diesel Engine Technology
