Golf 4 won't start? Troubleshooting guide
Klima96
Karma: +6 / -1   Thank you, like it!
Post20-06-2007, 15:26    Subject: Golf 4 won't start? Troubleshooting guide Quote
Hello.
I'm having a problem with my Golf 4 1.4, manufactured in 2000.
When you turn the key the first time, the engine doesn't start at all. There's no cranking, no clicking.
Turned the key once – then turned it again, and the car started.
In recent days, it sometimes takes several attempts.
The same thing happens with both car keys.
No errors stored in the error memory.
Could the relay or the ignition switch be defective?
I need help.
Golf 4 TDI PD 96 KW 6 Gang ASZ ERF
Jetzt 114 Kw nach *** Chip
Translated on 04-09-2026, 14:04.
brezelmann01
Post20-06-2007, 17:00    Subject: Golf 4 won't start? Troubleshooting guide Quote
Based on your description, I suspect a faulty ignition starter switch. It would be best to measure the voltage that arrives at the starter motor, specifically at the THIN wire at the front. There is no relay between the starter contact on the switch and the starter motor itself.
Translated on 04-09-2026, 14:05.
No new posts Doku Lupo 6X1 MJ 2002, Engine will not start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, from 5/99, Rear door lock not working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Window doesn't close Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. 2.0TDi won't start Diesel Engine Technology
No new posts VW Polo 6N2 Won't Start - WFS Error Codes On-Board Diagnostics (OBD)
No new posts Car won't start after water damage Diesel Engine Technology
No new posts 2006 Touran central locking not always working Electrical Systems, Vehicle Electronics, Multimedia
