VW 1.9 TDI Oil Leak: ARL Engine - Fix It!
599dxx
Post04-07-2017, 16:20    Subject: VW 1.9 TDI Oil Leak: ARL Engine - Fix It! Quote
The engine is installed in a Seat Leon Syncro. The engine and turbocharger (Garrett GT1749VB) have approximately 70,000 km (43,500 miles) on them. It has been chipped and a DPF (Diesel Particulate Filter) has been retrofitted. The described problem occurred even without the chip and without the DPF. It is obviously a problem that occurs more frequently with the ARL engine.
Here's the translation:
There is always a drop of oil hanging from the connections to the intercooler and on the turbocharger itself icon_sad.gif. Occasionally, a drop will also fall off icon_sad.gif. This certainly doesn't noticeably affect the oil consumption, which is about 1 liter per 5000 km... rather less. Nevertheless, the oil loss is not desirable. The axle boot underneath the turbocharger is always very oily }.
Is it really necessary to accept this oil leak, or are there ways to fix it or at least minimize it? I was wondering if it could be related to the oil return line from the turbocharger (only the supply line was replaced according to Garrett's instructions). Or could it be due to inadequate crankcase ventilation?
Helpful suggestions are very welcome!
Best regards from the Westerwald region...
Hardy.
Translated on 30-10-2026, 13:54.
chli1976
Post04-07-2017, 17:39    Subject: VW 1.9 TDI Oil Leak: ARL Engine - Fix It! Quote
"I once had a similar issue with an A4. In that case, the valve cover/crankcase ventilation system was defective. It was pushing oil directly into the exhaust/DPF. You could clearly see it when you removed the exhaust from the turbo."
It's normal for there to always be a small amount of oil in the intercooler system.
When I bought my Golf IV 16 years ago, I checked it out from underneath with 1700 km on the odometer, and I saw that the intercooler hose had a crack right after the turbo, and there were oil droplets hanging from it.
VCDS
Translated on 30-10-2026, 13:56.
599dxx
Post06-07-2017, 17:05    Subject: VAG ARL Engine Oil Leak: Causes & Fixes Quote
Hello chli1976,
Thanks for the information! That doesn't give much hope that we can do anything about it, at least not about the oil in the hydraulic fluid. As for the dripping on the loader itself, I might replace the return line after all... but I don't have much hope.
Perhaps there are other experiences to be shared as well?
Hardy.
Translated on 30-10-2026, 13:57.
Post13-07-2017, 14:56    Subject: VW 1.9 TDI Oil Leak: ARL Engine - Fix It! Quote
If I remember correctly, there were once modified (green) O-rings with a thicker profile available as a replacement part for this problem. Assuming the oil is leaking from the intercooler system...
Translated on 30-10-2026, 13:58.
599dxx
Post13-07-2017, 15:34    Subject: VW 1.9 TDI Oil Leak: ARL Engine - Fix It! Quote
Hello Roger,
"Thank you for the information. Yes, the oil leak affects both connections to the lowest points of the cooling system. I've also read somewhere about using thicker O-rings. Does anyone perhaps know the part numbers?"
Hardy.
Translated on 30-10-2026, 13:59.
Post13-07-2017, 19:53    Subject: VW 1.9 TDI Oil Leak: ARL Engine - Fix It! Quote
AFAIK, only the modified rings are being supplied now. While you're at it, also check the retaining clips on the connectors for wear, as they can become loose due to engine vibrations. This is a known issue. They tend to leak first, and then eventually break off.
599dxx
Post13-07-2017, 20:47    Subject: VW 1.9 TDI Oil Leak: ARL Engine - Fix It! Quote
Hello and thank you for the information!
Unfortunately, I'm also experiencing the problem with the worn aluminum fittings on the quick-release couplings. When I replace the O-rings, I'll likely need to replace the hoses as well. However, the car already has 466,000 kilometers (the coolant and hoses are still the original ones).
Hardy.
Translated on 30-10-2026, 14:00.
Nebelkerze
Post01-12-2017, 16:07    Subject: Problem Solved: Quick Fix & Solutions Quote
After the hoses to the cooling system were replaced, everything is quiet.
Thank you for your contributions!
Translated on 30-10-2026, 14:01.
No new posts Oil Leak Motor Block: AFB & AKN Engine Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Severe oil leak at the cylinder head, AJM engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ATF oil leak on 74 kW TDI engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil Leak V6 TDI: Causes & Fixes Diesel Engine Technology
No new posts Fuel Injectors Audi A6 2.5 TDI 140 HP AEL On-Board Diagnostics (OBD)
No new posts VW/Audi V6 TDI AKE: Starting Problems Diesel Engine Technology
No new posts Audi A4 B5 Automatic Transmission Problems? Transmission, Chassis, Body & Interior
