3L_Lupo_defekt
13-02-2007, 15:48 Subject: Lupo 3L ABS Control Unit: Reprogramming Guide |
The ABS control unit in my Lupo 3L (ABS control unit part number 6E0 907 379) is defective.
"I just got one from a Lupo 50hp gasoline engine (1J0 907 379 G), installed it, and now I'm getting the error message 'Control unit incorrectly coded' in the diagnostic system."
Can it be re-encoded?
The current code is 05703 WSC 01233.
Shouldn't the new one then be 05623 with WSC 01286? ??????????
Translated on 04-09-2026, 8:38.
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
13-02-2007, 20:14 Subject: Lupo 3L ABS Control Unit: Reprogramming Guide |
The WSC is the workshop code, and it doesn't matter...
Regarding reprogramming: It's worth trying. However, since the part number is different, it's questionable whether the process will be successful and whether the control unit is even compatible with the vehicle.
Translated on 04-09-2026, 8:39.
Profile PM WWW Garage |
Ross-Tech-Support Profi-Schrauber
13-02-2007, 21:10 Subject: Lupo 3L ABS Control Unit: Reprogramming Guide |
How do you actually determine that these control units are compatible?
6E0 907 379 = Conti/Teves MK30
1J0 907 379 G = Conti/Teves MK20
Install the correct control unit, and then it will also work with the vehicle. What you're trying to do here can actually only be recorded under "Low-Value Business Transactions" (LBBT).
Translated on 04-09-2026, 8:40.
3L_Lupo_defekt
13-02-2007, 22:17 Subject: Lupo 3L ABS Control Unit: Reprogramming Guide |
Okay, I've seen in several posts about people remapping the engine control unit (ECU) from a Golf to a Passat.
ABS control unit read.
The question is whether anyone has ever tried both variations (see above).
According to VAG, the parts with part numbers 6E0 907 375 and 6E0 907 379 A should also be compatible.
The frustrating thing is: the friendly VAG dealer wants a whopping 497 euros for the part, and the 3L ABS control units (6E0 907 375) are quite rare to find used.
P.S. The hydraulic blocks underneath where the part is located are identical in both vehicles.
Translated on 04-09-2026, 8:41.
14-02-2007, 0:14 Subject: Lupo 3L ABS Control Unit: Reprogramming Guide |
May I ask which VAG-COM version and hardware you are using for the reprogramming?
Translated on 04-09-2026, 8:42.
3L_Lupo_defekt
14-02-2007, 8:51 Subject: Lupo 3L ABS Control Unit: Reprogramming Guide |
I have been using a diagnostic tool borrowed from a friend who runs a car repair shop.
The device is made by Bosch.
I will also be purchasing a VAG-Com system with the necessary hardware. I would be grateful for any recommendations for the Lupo 3L â which one should I buy? Does it need to be CAN-bus compatible, or is KKL sufficient?
Translated on 04-09-2026, 8:43.
dakoal Blaumann
Joined: 05/31/2005 Posts: 66 Karma: +5 / -0 Location: Hausleiten
14-02-2007, 15:53 Subject: Lupo 3L ABS Control Unit: Reprogramming Guide |
Look closely...
in the "Basic Diagnostic Equipment" department.
http://shop.dieselschrauber.de/
Sure, here's the translation:
"Best regards," or "Sincerely,".
dakoal ____________________________________
Audi A6 Avant (C4) 2,5TDIi MKB:AEL, BJ 1995 @ 220tkm
VW Golf III 1,9D MKB:1Y, BJ 1995 @ 182tkm R.I.P. (Rest in Poland)
Profile PM Email |
pete121
Joined: 05/24/2007 Posts: 7 Karma: +0 / -0 Location: 49124 Kloster Oesede
24-05-2007, 23:42 Subject: Lupo 3L ABS Control Unit: Reprogramming Guide |
"Hello, I'm new here and looking for a solution to get my 3L (1.2 TDI, engine code ANY) engine running without the transmission control unit, as I want to convert the transmission to a manual gearbox."
Can the engine control unit be programmed to function without a separate transmission control unit?
Peter.
Translated on 04-09-2026, 8:44.
Jochen_145 Guest
25-05-2007, 11:52 Subject: Lupo 3L ABS Control Unit: Reprogramming Guide |
I recently read that even VAG (Volkswagen Group) offers the option to replace the semi-automatic transmissions on the 3L TDI models with manual transmissions.
Therefore, the recoding to manual mode should either be possible or unnecessary. However, Sebastian needs to confirm or correct this  .
Interesting that the conversion can also be done by VAG.
At the very least, this will cause you to lose the '3L consumption' status.
Best regards, Jochen.
Translated on 04-09-2026, 8:45.
pete121
25-05-2007, 12:37 Subject: Lupo 3L ABS Control Unit: Reprogramming Guide |
If that were the case, that would be absolutely fantastic. It would be great if someone had more detailed information.
peter
Translated on 04-09-2026, 8:46.
pete121
27-05-2007, 18:48 Subject: Lupo 3L ABS Control Unit: Reprogramming Guide |
What about "flash boosters" or similar devices that allow access to the engine control unit? Could I use such a device to reprogram the ECU of a Lupo 3L in a way that allows the engine to run without the transmission control unit?
I would be very grateful for any tips!
peter Lupo 3L 1,2 TDI 419.000 km ANY 8/99
Prototyp-Getriebesteuergerät
27-05-2007, 19:18 Subject: Lupo 3L ABS Control Unit: Reprogramming Guide |
So far, you're only making theoretical leaps, but it seems you haven't looked at the real data yet. The 085 is just an automated manual transmission, and as far as I can tell, the engine electronics treat it like a normal manual transmission. From this perspective, the conversion shouldn't be a problem; besides, we've already gotten much more complex things working...
Translated on 04-09-2026, 8:47.
pete121
28-05-2007, 11:47 Subject: Lupo 3L ABS Control Unit: Reprogramming Guide |
The engine control unit (ECU) receives data from the transmission control unit (TCU) regarding the selected gear and the clutch actuator. Without this data, the ECU initially prevents the engine from starting. If I disconnect the TCU from the CAN bus, then essentially nothing will work.
Sure, I'll start with some theoretical considerations, and I'm hoping you can give me some advice so I can practically implement my project. For me, there are currently several options: I could either call several tuning workshops and get quotes for reprogramming the engine control unit. Alternatively, I could buy a flasher with software for my own use, but that doesn't seem cost-effective for a single reprogramming. Besides, I'm not yet sure if I can rewrite the software the way I want to.
That's why I signed up here, because this forum and its members seemed the most knowledgeable to me. So, what should I do?
Happy Pentecost from the Teutoburg Forest!
Peter. Lupo 3L 1,2 TDI 419.000 km ANY 8/99
Translated on 04-09-2026, 8:49.
pete121
30-05-2007, 14:31 Subject: Lupo 3L ABS Control Unit: Reprogramming Guide |
Hello Hello
"Does anyone have any ideas? I've already called several tuning shops. But all of them refuse to reprogram the engine control unit, citing "liability reasons"."
How do I get the engine to start? Please help me!
Translated on 04-09-2026, 8:50.
Jochen_145 Guest
30-05-2007, 14:58 Subject: Lupo 3L ABS Control Unit: Reprogramming Guide |
Have you already inquired with Volkswagen about what's involved in the 'official' conversion process?
'The transmission solenoid (SG) will likely be removed as well, and the car will still run (presumably).'
Translated on 04-09-2026, 8:51.
pete121
30-05-2007, 15:01 Subject: Lupo 3L ABS Control Unit: Reprogramming Guide |
I have inquired with several VW workshops and also the VW hotline. Such an action is not known  .
As I said - no engine start without a transmission control unit! Lupo 3L 1,2 TDI 419.000 km ANY 8/99
