Holger247 wrote: |
Sure, the tensioners and the Wapu will be replaced with new ones.
Tensioner pulleys are definitely important!!! Water pump -> only necessary if it's attached to the timing belt (is this the case with the ALH engine?). If you're not a mechanic, the water pump should last at least 200,000 km!
[/quote]
Holger247 wrote: |
How is the fitting on the crankshaft pulley?
Is this still an issue with this engine?
This might be fixed (only a 1Z issue)!!!
Holger247 wrote: |
Do these bearing shells on the fuel injection pump also need to be replaced as a precautionary measure? |
No! For me, it didn't solve the cold start problem after 174,000 km on the 1Z engine! Just check if the shaft has any play (the limit is 0.3 mm!!).
Do you have any specialized tools?
"When installing the timing belt, rotate the crankshaft a small amount clockwise (but only a small amount, without forcing it -> the OT mark should be shifted about 1 cm!). This will make it easier to get the belt onto the camshaft sprocket. Then, return the crankshaft to the OT position for cylinder 1, and then tension the tensioner to the specified value (without tightening it) and release it. If the OT mark has moved after this, the timing belt is not yet seated correctly -> this saves you work!"
"Always use a holding tool when loosening and tightening the camshaft sprocket!!! To loosen the camshaft sprocket (with the locking mechanism not yet engaged), I rotate the crankshaft 90° with the old timing belt still tensioned (direction doesn't matter) to bring cylinder 1 to a position slightly before top dead center, so that if the sprocket slips, no valve will hit the piston (I'm very careful). Afterwards, lock the camshaft and rotate the crankshaft 90° back."
Good luck.
Best regards, Christian
