Brake Assist Error: ESP Turns Off Repeatedly
Torfhausracer
Post03-10-2007, 21:06    Subject: Brake Assist Error: ESP Turns Off Repeatedly Quote
Hello there...
"I've been having a problem with my G4 ALH, manufactured in 2000, where the ESP light occasionally illuminates after starting the engine. This usually happens when the vehicle has been parked for more than about 10 hours, or when the brake pedal is repeatedly pressed while the engine is not running, which depletes the vacuum in the brake booster. After a second engine start, the light then turns off. The diagnostic scan revealed error code 00814 035, which indicates a problem with the solenoid valve for the brake pressure sensor (N247). I had the brake booster replaced, but the problem persists."
Does anyone have experience with this?
Mathias
Translated on 23-10-2026, 23:15.
No new posts Doku Lupo 6X1 MJ 2002, Engine will not start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Service reminder does not expire after WIV reset. On-Board Diagnostics (OBD)
No new posts 14V Charging: Why It Takes 3 Minutes? Transmission, Chassis, Body & Interior
No new posts Car won't start after water damage Diesel Engine Technology
No new posts Brake Light Stays On: Causes & Fixes Diesel Engine Technology
