Dieselmike Guest
09-11-2007, 14:35 Subject: AKE Troubleshooting: Common Errors and Solutions |
Hello.
I installed an AKE (turbocharger) in my T3. The engine originally came with an automatic transmission, but I'm using a Porsche gearbox. I've fixed the issues related to the crankshaft sensor (it took about 4 months), and the engine runs well. However, I think it's running in limp mode because the acceleration with a maximum boost pressure of 0.7 bar is not satisfactory. It feels like it's pulling like chewing gum. I took it directly to Audi, and they couldn't find anything specific, except that I have error codes stored that they can't clear (fuel injector), which, according to Audi, is not normal.
Question:
Is there anyone here who is an expert and can help me with my car and take a look at it? Of course, not for free.
Which tuner is capable of reprogramming the engine control unit (ECU) and optimizing it for the specific car?
Best regards and thank you.
Mike.
Translated on 22-09-2026, 11:04.
christians Profi-Schrauber
11-11-2007, 0:15 Subject: AKE Troubleshooting: Common Errors and Solutions |
A faulty injector control valve does not trigger the emergency mode, and the VP44 pump does not necessarily require it.
I'm not really knowledgeable about engine control units (ECUs), but usually, they can be adapted to either manual or automatic transmissions. So, it's not really proper programming. As far as I know, the engine and transmission control units communicate in the A6. If the automatic transmission isn't present and therefore not sending any signals, that could potentially be the reason for the limp-home mode.
Perhaps this question would be better suited for the "Engine Control Units and Diagnostics" forum. Gruß Christian
Translated on 22-09-2026, 11:05.
Dieselmike Guest
16-11-2007, 14:48 Subject: AKE Troubleshooting: Common Errors and Solutions |
Thanks for moving it. The issue with the transmission could certainly be related. Try to get a control unit from a similar vehicle. To do this, I need to remove the old one so that Audi can determine a comparable vehicle type.
Translated on 22-09-2026, 11:06.
mullemaus Guest
16-11-2007, 23:04 Subject: AKE Troubleshooting: Common Errors and Solutions |
You can usually reprogram that from the automatic transmission. If that doesn't work, reflashing it is also sufficient  . You don't necessarily need a new control unit for that.
Translated on 22-09-2026, 11:07.
Dieselmike Guest
19-11-2007, 12:12 Subject: AKE Troubleshooting: Common Errors and Solutions |
Which brings us back to the question of who would do something like that (reflashing the device).
Thank you for your help.
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
19-11-2007, 14:17 Subject: AKE Troubleshooting: Common Errors and Solutions |
You have a private message.
Profile PM WWW Garage |
