Error: Lower limit setting for quantity control in AFN
moser7
Post20-12-2002, 21:16    Subject: Error: Lower limit setting for quantity control in AFN Quote
Hello!
I've been experiencing this error intermittently for the past two years:
Quantity setting lower limit entered in the error memory.
I have a Hopa plug-in tuning system installed. Is that the reason, or does it not matter?
Furthermore, for the past year, there has been a jerking sensation when accelerating from low RPMs, which suggests a partially slipping clutch. However, I had a new dual-mass flywheel installed last year (which, in this case, included a new clutch), but the rattling noise persisted.
Could this possibly be related to the fuel injection pump?
Mileage: 165,000 km.
Thank you for your help.
P.S. The workshop wants to take a look at the quantity adjuster. Does that help?
Karma: +784 / -0   Thank you, like it!
Post20-12-2002, 21:33    Subject: Error: Lower limit setting for quantity control in AFN Quote
It's likely that your device is activating too early in the lower load range (idle state).
Just disable the device and see if the problem persists.
moser7
Post21-12-2002, 20:19    Subject: Error: Lower limit setting for quantity control in AFN Quote
I've had this box for 3 years now, and it wasn't like this back then.
More importantly, the question was whether the module was causing this 'lower limit quantity setting' error, or whether there was actually a fault. icon_exclaim.gif
Post21-12-2002, 21:31    Subject: Error: Lower limit setting for quantity control in AFN Quote
Then just open the box, and you'll know.
moser7
Post23-12-2002, 13:22    Subject: Error: Lower limit setting for quantity control in AFN Quote
Yes, Grandmaster, Sir!
I did it, and...
The performance is the same as with the Modul version.
So, the thing is broken! (After two years)
Since I got it at a special price without VAT back then, I really can't send it in for service.
I think I'll install the 10Cent luxury version. This is likely nothing more than this Hopa module.
No new posts Touran Fehler Licht (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 01268 Quantity setting (upper limit) error, likely found On-Board Diagnostics (OBD)
No new posts neuer Fehler: 17970 - Mengensteller (N146) oberer Anschlag Diesel Engine Technology
No new posts SOLUTION on page 2 - TDI AFN - Quantity adjuster, upper stop Diesel Engine Technology
No new posts Fehler Mengensteller -N146 Diesel Engine Technology
