Ibiza 6K Brake Pads: Replacement & Installation
Post28-12-2007, 13:09    Subject: Ibiza 6K Brake Pads: Replacement & Installation Quote
After approximately 83,000 km, the front brakes on our ALH Ibiza (256mm, internally ventilated) are starting to look like they need to be replaced.
The comparison between the real object and the document confused me a bit.
On the saddles, there's the bold name Lucas, and Girling is the only one who knows the details icon_eek.gif.
The (initial) brake pads are labeled "Jurid," which corresponds to the information in the documentation; according to the documentation, the brake pads for the 280mm brakes are from either Galfer or Pagit.
Can I now install brake pads 1HM 698 151 A and new discs 6N0 615 301 D (which, according to the records, are for Girling!), or is it likely to fail because of the Lucas calipers?
Unfortunately, I was unable to identify any VAG part numbers without disassembling the calipers icon_evil.gif.
Translated on 05-10-2026, 1:10.
Avatar-Jan6K
Post28-12-2007, 13:42    Subject: Ibiza 6K Brake Pads: Replacement & Installation Quote
Hi Ulf,
Even though my Ibiza already had its brake change (last year, the brake pads and discs were at the wear limit for the TÜV inspection, with about 87,000 km on the clock), I can't really help you because the ASV-Ibi has 280mm brakes, and the part numbers wouldn't be relevant (if you still want them, I can look for the invoice... I had it done at a small independent workshop back then).
I'm guessing you have 14-inch rims... otherwise, you would definitely be considering the upgrade to the 280 system, right?
Jan.
1Z5 CFHF / AHB H4D
Translated on 05-10-2026, 1:12.
BM
Avatar-BM
Post28-12-2007, 15:40    Subject: Ibiza 6K Brake Pads: Replacement & Installation Quote
Can I now install brake pads 1HM 698 151 A and new discs 6N0 615 301 D (which, according to the records, are for Girling!), or will it likely fail due to the Lucas calipers?
I think that should be correct. According to the documentation, there's nothing else available for the 256mm brake system. It refers to the Girling system, but the manufacturer could also be Lucas.
I would go with the entire set from Pagid – it only costs half as much, and there are no issues with the quality. The only difference is that the discs are not coated against rust.
3B5 AJM
Translated on 05-10-2026, 1:14.
Post28-12-2007, 17:43    Subject: Ibiza 6K Brake Pads: Replacement & Installation Quote
BM wrote:
According to the documentation, there is nothing else available for the 256mm brake system. The system is referred to as the Girling system.
However, the manufacturer could also be Lucas.
Ah, thank you, that reassures me a bit.
icon_confused.gifI would take the whole set from Pagid -- it only costs half as much, and there are no quality issues. The only difference is that the discs are not coated against rust.} And do you find Pagid at general parts stores?
Looking at the edges of the discs, it seems they never had any rust protection applied }.
@JanViewing profile: Jan: It's Christel's Ibiza, and nothing is going to be changed there - it's a women-only place!
(Adjusting vintage equipment doesn't fall under the category of "tinkering" here...)
Translated on 05-10-2026, 1:15.
BM
Avatar-BM
Post28-12-2007, 18:40    Subject: Ibiza 6K Brake Pads: Replacement & Installation Quote
And are Pagid brake pads available at the general parts supplier?
Sure, you can find it at a good specialty store, or at ***lekl**s icon_wink.gif.
3B5 AJM
Translated on 05-10-2026, 1:17.
No new posts Golf 1J documentary, low-frequency noise from rear brakes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Electrical problem in wet conditions, Seat Ibiza 6L ASZ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N / Ibiza 6L / Fabia 2: Generator does not charge Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ibiza 6K TDI: Best Brakes & Brake Pads Transmission, Chassis, Body & Interior
No new posts Brake Noise: Causes and Solutions Transmission, Chassis, Body & Interior
No new posts Brakes on the Golf 3 Transmission, Chassis, Body & Interior
No new posts Jerky braking Transmission, Chassis, Body & Interior
