VW Polo 6N2 Won't Start - WFS Error Codes
dermoe
Post04-02-2008, 20:43    Subject: VW Polo 6N2 Won't Start - WFS Error Codes Quote
Car: Polo 6n2 (AMF 1.4 TDI)
After an alarm system was installed, which required removing the steering column cover, the engine will no longer start.
The starter relay is not responding at all. After some time, the "warning" light flashes, and there is a beeping sound 3 times. icon_sad.gif
Attempts were made to start the vehicle using the plastic key (is that even possible?), as well as with a potentially faulty key (transponder). Therefore, there may be an error entry (incorrect key) or a wiring defect.
VAG-COM says:
Engine control unit:
Code:
2 Faults Found:
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-10 - - - Intermittent
18044 - Powertrain Data Bus: Missing Message from Airbag Controller
            P1636 - 35-10 - - - Intermittent
Readiness: N/A
These errors can be deleted, but they reappear immediately.
The WFS service also had 3 error messages, but I was able to permanently delete them.
The cable between the reading coil and the control unit seems to be okay, but new cables have been installed in that area (potential source of error). The airbag control unit indicates that all 4 airbags are functioning correctly. No other errors are present.
Greetings, Moritz.
Translated on 14-10-2026, 16:28.
dermoe
Post04-02-2008, 22:21    Subject: VW Polo 6N2 Won't Start - WFS Error Codes Quote
According to the instructions, the plastic key should also work.
I now suspect that it's likely a faulty ignition switch (the active WFS probably only engages after the engine starts). Can this be checked with VAG-COM?
Greetings, Moritz.
Translated on 14-10-2026, 16:30.
3 Phasen Biber
Karma: +2 / -1   Thank you, like it!
2001 Volkswagen Golf
Post04-02-2008, 22:41    Subject: VW Polo 6N2 Won't Start - WFS Error Codes Quote
If it is indeed your Polo icon_twisted.gif.
What exactly is the WFS-Stg? icon_eek.gif WFS is integrated into the speedometer/MSG!
Do you already know how a WFS (Web Feature Service) works?
P.S. Questions like these are generally not welcome here!
ehemals G4 ASZ, jetzt G4 ARL
Translated on 14-10-2026, 16:31.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post04-02-2008, 22:43    Subject: VW Polo 6N2 Won't Start - WFS Error Codes Quote
I also think that it would have to start first before immediately shutting off. Perhaps the connector on the ignition switch has come loose, or a cable may have broken. Or, the action of trying to start it may have triggered a defect in the already unstable part.
Okay, or maybe I'm wrong... You just have to check if everything is working correctly, like verifying the proper connection of a 50-amp breaker to the magnetic contactor, for example.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
mullemaus
Post04-02-2008, 23:46    Subject: VW Polo 6N2 Won't Start - WFS Error Codes Quote
What exactly is the WFS system? icon_eek.gif WFS is integrated into the speedometer/MSG!
Yes, in vehicles like the T4 and Polo, there is an external WFS-SG (Vehicle Functional Safety System - Security Gateway) that contains the key data. Just like the speedometer in other vehicles. The Polo, like the T4, can operate without a speedometer because other systems rely on the key data stored within it icon_wink.gif.
So, nothing about the speedometer in this case icon_wink.gif.
Translated on 14-10-2026, 16:32.
dermoe
Post05-02-2008, 0:06    Subject: VW Polo 6N2 Won't Start - WFS Error Codes Quote
Thank you very much for the tip about terminal 50 - teileklaus! I just measured the ignition switch and discovered a loose connector under the fuse box (easily accessible). So, if there's a "Hall of DAU"... icon_rolleyes.gif
Thank you also to mullemaus/3phasenbiber for the answers.
Greetings, Moritz.
Translated on 14-10-2026, 16:34.
No new posts Doku Lupo 6X1 MJ 2002, Engine will not start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L, Airbag STG error cannot be cleared Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts The Electric Car - Why It Isn't Taking Off Technical Articles
This topic is locked, you cannot edit or reply. 2.0TDi won't start Diesel Engine Technology
No new posts Car won't start after water damage Diesel Engine Technology
No new posts Transmission Control Unit: Recording Issues On-Board Diagnostics (OBD)
No new posts AFN Engine Control Unit: No Reprogramming On-Board Diagnostics (OBD)
