SDI Starter Motor - Replacement & Repair
Kopi
Post29-01-2008, 20:49    Subject: SDI Starter Motor - Replacement & Repair Quote
Hello.
When marinizing my SDI 1.9 (year 2004), I have to mount the starter motor on the engine side, but the flywheel's starter ring gear is on the opposite side. However, the starter motor is now rotating in the wrong direction. I need a starter motor that rotates clockwise, and one that also fits the teeth of the starter ring gear.
Best regards, Kopi.
Translated on 22-10-2026, 21:49.
Back to top Profile PM Email
kuestenkuddel
Post02-02-2008, 18:48    Subject: SDI Starter Motor - Replacement & Repair Quote
Hello Kopi.
Your Polo starter motor has the part number DB (L) 12V 2.0KW.
Looking for a DB (R) 12V 2.0KW starter motor compatible with a VW LT 2.5 TDI.
With 1.8 kW, the motor will definitely start, and it's a DB (R) 12V 1.8 kW model, which you can find in Audi A4 and A6 vehicles.
or in a VW Passat 1.9 TDI.
Did you manage to fix the fuel injection pump?
Best regards, Kurt.
Translated on 22-10-2026, 21:50.
Kopi
Post02-02-2008, 19:09    Subject: Starter Motor SDI - Replacement & Repair Quote
Thank you for the tip.
The pump was sent back to me because the mechanical parts don't fit into the SDI pump (the casing is too small). However, another company contacted me and said they can modify it for 500 euros. Let's see if it works out. And even if 10 people tell me it's not possible, I won't give up.
Best regards, Kopi.
Translated on 22-10-2026, 21:51.
kuestenkuddel
Post06-02-2008, 22:24    Subject: SDI Starter Motor - Replacement & Repair Quote
Hi Kopi.
I wouldn't worry *too* much about the fuel injection pump.
If I were in your position, I would install a standard mechanical Bosch VE injection pump in your car and then replace the plunger and high-pressure component.
Where is your cutter located?
Best regards, Kurt.
Translated on 22-10-2026, 21:52.
Kopi
Post07-02-2008, 17:34    Subject: Fuel Injection Pump Quote
Hello.
My boat used to be a single hull. It was sawn in half lengthwise in Poland, separated by 1.5 meters, and then welded back together as a catamaran with a motor. It's currently located in Stargniß, near Ückeritz, on the island of Usedom. However, the fuel pump for the SDI engine is supposed to have a higher injection pressure, and I would really like everything to be original and match.
Best regards, Kopi.
Translated on 22-10-2026, 21:53.
No new posts Starter Motor Noise: VW Golf 4 & Similar Troubleshooting & Guides
No new posts Starter Motor Touran BRU Diesel Engine Technology
No new posts TDI Starter Compatibility: Find the Right One Diesel Engine Technology
No new posts Audi A4 B7 Starter Motor 3.0 TDI Electrical Systems, Vehicle Electronics, Multimedia
No new posts Starter Motor Problems: Troubleshooting & Solutions Diesel Engine Technology
