12-03-2008, 14:55 Subject: |
Vag-Com Diesel enthusiasts... that's where VCDS comes in  .
I didn't even know what he wanted when an American asked me if I had "wäg kom."
Americans tend to shorten words and then pronounce the shortened version - for example, "Jeep."
It's good that it doesn't work well with VCDS.
m; Transparency, Teamwork
Translated on 23-10-2026, 5:09.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18142 Karma: +807 / -0 Location: St.Gallen 2018 Volkswagen T6
12-03-2008, 16:27 Subject: |
VCDS stands for Vag- Com Diagnostic System. The reason for the short-term renaming is a legal issue regarding the registration of VAG-COM as a trademark in the United States.
Apart from the unpronounceable abbreviation, nothing else changes.
Translated on 23-10-2026, 5:10.
Profile PM WWW Garage |
mullemaus Guest
13-03-2008, 0:10 Subject: VCDS: What happened to VAG-Com? |
The latest beta version is called VCDS 803.0.
803.1 already since the day before yesterday
Translated on 23-10-2026, 5:11.
Uwe@Ross-Tech Guest
13-03-2008, 3:25 Subject: |
Except for the unpronounceable abbreviation.
Vau Ceh Deh Ess? Vau Weh started with such things.
-Uwe-
haithamina Schrauber
Joined: 05/15/2006 Posts: 666 Karma: +27 / -3 Location: 69221 Dossenheim
13-03-2008, 8:57 Subject: |
@ Martin et al.: "GP," meaning "general purpose," doesn't seem to be the origin of the word. It's quite impressive, that "www."
http://de.wikipedia.org/wiki/Jeep
haithamina 3G5, 110 kW, DFGA, TGV, Variant HL 2018-
Translated on 23-10-2026, 5:12.
13-03-2008, 10:38 Subject: |
@ haithamina
I never said "General Purpose"  , but I meant pronouncing "GP" (whether it's a Ford code or something else).
And the Wikipedia article itself states that it is _unclear_.
No matter what, apparently people over there express everything openly... although they will likely have problems with "Wie Zieh De Es"  .
Profile PM Garage |
Uwe@Ross-Tech Guest
14-03-2008, 4:33 Subject: |
No matter what, apparently people over there are expressing everything openly... although they will likely have problems with '  'Wie Zieh De Es'.
No, not everything is pronounced literally, especially when it's obviously not possible. For example, 'IBM' is always pronounced 'Ei Bie Emm'.
In American English, VCDS is said: Vie Zie Die Ess.  It's really not a problem, and definitely better than paying lawyers for the next 5 years.
Best,
-Uwe-
Translated on 23-10-2026, 5:14.
