OBD for Mercedes Sprinter: Diagnostics & Repair
vwtommy
Post21-03-2008, 23:50    Subject: OBD for Mercedes Sprinter: Diagnostics & Repair Quote
"Hi, my father has a Mercedes-Benz Sprinter, model year 2001, 313CDI, and for some time now, the preheating indicator light has been coming on for a few minutes about 30 seconds after starting the engine. Also, the engine seems to have relatively low power since then. So, I thought I'd check it with OBD, but no luck. The connector for the KKL interface that I use for my Golf doesn't fit here, because Mercedes, of course, uses its own round connector, which is completely unnecessary. Well, it's not a huge deal to read the data just once, so I thought I could just clip it on with alligator clips. But on this car, every control unit has its own pin. I have the pinout information, also from OBD, but does anyone know if I need the K or the L wire?"
Thank you in advance for your help.
Best regards, Thomas.
Translated on 17-10-2026, 19:36.
Uwe@Ross-Tech
Post22-03-2008, 18:27    Subject: OBD for Mercedes Sprinter: Diagnostics & Repair Quote
http://shop.dieselschrauber.de/images/obd2_diagnose_lt_sprinter.jpg
Please provide the text you would like me to translate from German to English. I will then provide the translation without any explanations.
http://shop.dieselschrauber.de/product_info.php/cPath/25/products_id/51/
-Uwe-
Translated on 17-10-2026, 19:38.
luiggi
Post23-03-2008, 9:56    Subject: OBD for Mercedes Sprinter: Diagnostics & Repair Quote
If the preheating indicator light is illuminated or flashing, there is usually a problem with your glow plugs (one or more are defective), or with the preheating fuse/relay.
If there is an error in the engine control unit, the EDC warning light will illuminate.
Please check your spark plugs and the 80A fuse strip in the engine compartment.
chli1976
Post23-03-2008, 10:55    Subject: OBD for Mercedes Sprinter: Diagnostics & Repair Quote
I tried using this adapter with a Sprinter van manufactured in 1996, but it didn't work. Probably because that vehicle doesn't support OBD.
Translated on 17-10-2026, 19:39.
Post23-03-2008, 18:26    Subject: OBD for Mercedes Sprinter: Diagnostics & Repair Quote
chli1976 wrote:
I tried using this adapter with a Sprinter from 1996, but it didn't work.
Probably because that vehicle doesn't yet support OBD. }
Is it expected... and is access possible via control unit address 01?
chli1976
Post23-03-2008, 21:06    Subject: OBD for Mercedes Sprinter: Diagnostics & Repair Quote
I tried using both 01 Motorelektronik and OBD II.
Translated on 17-10-2026, 19:40.
No new posts Documentary: LD errors on the Sprinter 315CDI, two-stage ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Mercedes Sprinter 311 CDI misfires and EDC light is on Diesel Engine Technology
No new posts Mercedes-Benz Sprinter 907 BMS battery pairing Electrical Systems, Vehicle Electronics, Multimedia
No new posts Seatbelt Pretensioner Explodes in Mercedes Vito Transmission, Chassis, Body & Interior
No new posts Gearbox for LT/Sprinter models - compatibility guide (par... Transmission, Chassis, Body & Interior
