Swirl chamber extension, Golf 2 TD JR
Gremlin
Avatar-Gremlin
Karma: +92 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Post09-04-2008, 21:50    Subject: Swirl chamber extension, Golf 2 TD JR Quote
Hello everyone,
Unfortunately, I couldn't find anything suitable, even after searching on Google.
Vehicle: Golf 2, manufactured in 1990, equipped with a JR engine (1.6L turbocharged diesel).
What should be the amount of clearance between the combustion chamber inserts and the surrounding structure?
I read something in this forum about 0.07mm (AAZ engine), and on another site (T4-Wiki) something about 0.05mm??
Does anyone know more details?
Diesel_Rudi
Post11-04-2008, 9:39    Subject: Swirl chamber extension, Golf 2 TD JR Quote
Typically, the 'chamber lid' is located above... A necessary finishing cut/milling operation straightens everything out.
Hi!
No new posts Tuned 2.4L Diesel: Experiences & Modifications Diesel Engine Technology
No new posts Golf 2 TD: Temperature Problems & Solutions Diesel Engine Technology
No new posts Golf2 GTD Import: COC Paper Inspection Report Transmission, Chassis, Body & Interior
No new posts Golf 2: Read Error Codes with VAG-COM On-Board Diagnostics (OBD)
