Battery Drain: Audi A2 8Z0 MJ 2002 Doc (Solution)
Michael II
Post01-01-2003, 16:43    Subject: Battery Drain: Audi A2 8Z0 MJ 2002 Doc Quote
Battery drained due to a faulty or incorrectly configured tailgate lock.
Cause.
Battery discharge caused by pre-existing damage, defects, active consumers, or leakage currents.
Solution:
If a defective or improperly adjusted tailgate lock is identified as the cause of a fault or discharge of the starter battery, please perform the following checks:
A faulty or improperly adjusted tailgate lock can cause the trunk light to remain on for a short period after the tailgate is closed.
However, after 10 to 15 minutes, the trunk light is automatically turned off by the central locking control unit.
Please verify that the emergency shutdown function is working correctly.
If the emergency shut-off function is working correctly, then the tailgate lock cannot be the cause of the discharged or defective battery.
Tschüss
Michael II
Translated on 07-09-2026, 18:21.
Ratings - Battery Drain: Audi A2 8Z0 MJ 2002 Doc
No new posts Wind Noise in Audi A2 (8Z0) 2002: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, HVAC failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Q7 Battery Drains: Causes & Fixes Electrical Systems, Vehicle Electronics, Multimedia
No new posts Battery discharged overnight, alternator warm Electrical Systems, Vehicle Electronics, Multimedia
No new posts Golf 3 TDI Battery: Buy Now & Save! Diesel Engine Technology
No new posts AGM Battery Charging: How To & Tips On-Board Diagnostics (OBD)
