Wind Noise in Audi A2 (8Z0) 2002: Documentary (Solution)
Michael II
Post01-01-2003, 21:56    Subject: Wind Noise in Audi A2 (8Z0) 2002: Documentary Quote
Wind noise (whistling) in the area of the side mirrors, starting at approximately 70 km/h.
Cause:
Gap between the mirror housing and the mirror base is too large in the joint area.
Solution:
Disassemble the mirror housing and shorten the contact edge on the mirror housing by 2mm. This will reduce the gap between the mirror housing and the mirror base.
Tschüss
Michael II
Translated on 03-09-2026, 14:10.
Ratings - Wind Noise in Audi A2 (8Z0) 2002: Documentary
No new posts Audi A2 Noises: 8Z0 MJ 2002 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, HVAC failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 Wind Noise: Driver Side Fix & Causes Transmission, Chassis, Body & Interior
No new posts Car Noise: Trunk Wind Noise & Fixes Transmission, Chassis, Body & Interior
No new posts Sunroof, wind noise, rear washer motor, dark FIS Transmission, Chassis, Body & Interior
No new posts Passat TDI 2002: Euro 3 Specs & Info Diesel Engine Technology
