Cable-operated shifting (and other plastics) "bulge" or "swell"
Post24-05-2008, 23:01    Subject: Cable-operated shifting (and other plastics) "bulge" or "swell" Quote
Hi.
What's the best way to lubricate this ball on the cable-operated gear linkage where the shift knob ends?
I have Teflon spray, which helps, but not permanently. This ball and all the Climatronic mechanics are coated with a clear, transparent substance - that's what I need icon_wink.gif.
Plastics become brittle when exposed to oil derivatives.
Translated on 17-07-2026, 12:54.
BM
Avatar-BM
Post24-05-2008, 23:19    Subject: Cable-operated shifting (and other plastics) "bulge" or "swell" Quote
What's the best way to lubricate this ball on the cable shifter mechanism where the gear knob ends?
With polyurethane grease G 052 142 A2. As far as I know, it's a white paste.
3B5 AJM
Translated on 17-07-2026, 12:55.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post25-05-2008, 9:39    Subject: Cable-operated shifting (and other plastics) "bulge" or "swell" Quote
The urea grease I received for my brake pedal switch was brown.
As a thin film, it appears almost transparent.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Post25-05-2008, 12:43    Subject: Subject: Cable-operated shifting (and other plastics) - "bulky" or "chunky" Quote
dieselmartin wrote:
This sphere and all the Climatronic mechanics are smeared with a clear, transparent substance - I don't need that icon_wink.gif.
Silicone grease, at least, doesn't cause rubber-like seals to swell and is colorless and clear.
Translated on 17-07-2026, 12:56.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post28-05-2008, 23:49    Subject: Cable-operated shifting (and other plastics) "bulge" or "swell" Quote
I always use motorcycle chain lubricant for things like that.
It seeps into even the smallest cracks and adheres well once it dries.
Translated on 17-07-2026, 12:57.
Post29-05-2008, 6:27    Subject: Cable-operated shifting (and other plastics) "bulge" or "swell" Quote
Motorcycle chain lubricant: I recently used this on the plastic ball of an A2 gearbox last weekend. The internal gear selector had become jammed, and it took a long time to disassemble. As a result, everything was full of "crumbs." After removing and cleaning it, I sprayed a minimal amount of chain lubricant and wiped off the excess. Now it shifts like new!
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Powerbox DIY: Optimize Energy Consumption Diesel Engine Technology
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts Driving Too Dumb? A Brave New World Diesel Engine Technology
No new posts RNS315 Upgrade: Install "Discover Media" Now! Electrical Systems, Vehicle Electronics, Multimedia
