Golf 4 TDI 4Motion: Front axle noise?
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post07-06-2008, 19:43    Subject: Golf 4 TDI 4Motion: Front axle noise? Quote
hello
"For a few weeks now, I've been hearing a cracking sound in the area of the front axle. I've already replaced the tie rod ends, strut mount bushings, and axial ball joints. However, the cracking sound keeps coming back. It sometimes occurs when starting, braking, or steering."
I'm really at a loss and don't know what to do anymore... maybe someone here has experienced something similar before.
"MFG" is an abbreviation for "Mit freundlichen Grüßen," which means "Sincerely" or "Best regards" in English.
Audi SQ5 8R Cvub
Translated on 04-10-2026, 13:34.
Back to top Profile PM Email
Post07-06-2008, 19:45    Subject: Golf 4 TDI 4Motion: Front axle noise? Quote
Stabilizer gummies or rear lower control arm bushings.
pa-mm6
Post08-06-2008, 16:07    Subject: Golf 4 TDI 4Motion: Front axle noise? Quote
Hi.
Thanks for your tip. I've also looked at the Stabilo pens, and they actually seem to be in very good condition.
Could the tie rods potentially break? The TÜV (German technical inspection agency) mentioned them recently, although they said it wasn't a major issue.
Audi SQ5 8R Cvub
Translated on 04-10-2026, 13:35.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post08-06-2008, 16:28    Subject: Golf 4 TDI 4Motion: Front axle noise? Quote
pa-mm6 wrote:
Could the tie rods possibly break?
The TÜV (German technical inspection authority) mentioned them recently, saying that it's not a good thing. }
With a little help and a touch, you'll know.
You'll have to adjust the tire pressure anyway, otherwise it will affect the tires.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 04-10-2026, 13:36.
Post08-06-2008, 16:45    Subject: Golf 4 TDI 4Motion: Front axle noise? Quote
I have never seen a defect in my Stabigummies, but the VA (Valve Assembly) has made a cracking sound (knacked) twice... After replacing the gummies, everything was okay again. icon_twisted.gif
Translated on 04-10-2026, 13:37.
bloesch
Post09-06-2008, 21:47    Subject: Golf 4 TDI 4Motion: Front axle noise? Quote
Sure, rubber bands are useful for many things:
It squeaks, rattles, and creaks... but people rarely look at it.
They also changed quite quickly.
Okay... definitely check the feathers for cracks sometime... icon_eek.gif ... even the mechanic missed it recently... icon_rolleyes.gif ... it was also a little brittle... }
luiggi
Post11-06-2008, 17:38    Subject: Golf 4 TDI 4Motion: Front axle noise? Quote
Also, also, also. They are relatively quick to replace. Just be careful when ordering replacement parts for the 4Motion models, as they have a larger diameter.
Translated on 04-10-2026, 13:38.
pa-mm6
Post17-06-2008, 12:16    Subject: Golf 4 TDI 4Motion: Front axle noise? Quote
Hi.
Suddenly, the cracking sound almost disappears, and sometimes I don't notice it for a few days. Sometimes it occurs when parallel parking. The rubber bushings are actually new; I installed the R32 stabilizer bars last year, and I also installed new rubber bushings and brackets at the same time. They can't be bad again already... icon_confused.gif
Audi SQ5 8R Cvub
Translated on 04-10-2026, 13:39.
No new posts Golf 4 Motion, Year 2013, Problems with ASR/ESP/ABS/Autohold Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documented clutch failures in 4-Motion TDI-PD engines Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0044 AMF, Creaking Noise Front Axle Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 96´Golf III 1.9TDI 90PS knacken im bereich hinterachse Transmission, Chassis, Body & Interior
No new posts Golf 4 ARL: Installing a Parking Heater On-Board Diagnostics (OBD)
No new posts ESP Problem Golf 4 ARL 4Motion On-Board Diagnostics (OBD)
No new posts Golf 5 2.0 TDI 4-Motion rear brake caliper Transmission, Chassis, Body & Interior
