GRA Installation Error: Troubleshooting Guide
Määtes
Post01-01-2003, 18:31    Subject: GRA Installation Error: Troubleshooting Guide Quote
Hello!
Today I installed the gasoline particulate filter (GPF) in my Golf. The mechanical installation wasn't a problem, but connecting it to the connector on the engine control unit was a bit tricky.
I had to use spade connectors to attach the four wires of the GRA to the connector of the control unit because the pins absolutely wouldn't fit into the socket. However, everything went according to plan, including the power connection.
Upon the initial startup, everything was fine. However, after approximately 2 minutes of engine running time, the ABS light illuminated, followed by the red 'warning' light, and a triple beep sounded.
Ah yes, the GPU is enabled.
Does anyone have any idea what this could be?
Thank you in advance.
Translated on 27-07-2026, 23:00.
Michael II
Post01-01-2003, 20:54    Subject: GRA Installation Error: Troubleshooting Guide Quote
As always in such cases: have the error memory read out.
Perhaps the "Lüsterklemmen Action" also opened up unforeseen possibilities for making connections?
Tschüss
Michael II
Translated on 27-07-2026, 23:01.
olbetec
Post02-01-2003, 15:15    Subject: ABS System: Benefits & How It Works Quote
In my car, the GRA (Gravitational Resistance Assist) is powered through the brake light switch as a failsafe. If there's something wrong with that switch, the ABS (Anti-lock Braking System) will naturally start giving error messages.
Clarity will provide the exact error code.
Happily following the mess of cables.
Fabia I TDI, EZ06/01 (1,9/74kW, ATD)
Octavia II TDI DSG EZ11/06 (2,0/103kW, BMM)
Translated on 27-07-2026, 23:02.
Määtes
Post07-01-2003, 20:57    Subject: GRA Installation Error: Troubleshooting Guide Quote
The problem has resolved itself, and everything is working as it should now.
The installation was correct, however, the ABS fuse (which is located directly next to the tapped fuse) blew – a strange coincidence. Therefore, the error message only comes from the blown fuse.
After the exchange, everything is back to normal.
Thank you for the tips!
Translated on 27-07-2026, 23:03.
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Installation of an aftermarket seat heater Troubleshooting & Guides
No new posts Review and Installation: Kenwood KDC-DAB 4551U in a Peuge... Troubleshooting & Guides
No new posts GRA Error After Activation? Troubleshooting Guide. On-Board Diagnostics (OBD)
No new posts Media-In Retrofit: Troubleshooting Error Messages On-Board Diagnostics (OBD)
No new posts ACC Coding for A4 B8 FL After AHK Installation On-Board Diagnostics (OBD)
No new posts Adjust timing belt tension after installation Diesel Engine Technology
