New Car Key / Immobilizer Replacement
rblaas
Avatar-rblaas
Post30-07-2008, 17:23    Subject: New Car Key / Immobilizer Replacement Quote
Hello everyone.
I'm driving a 2001 3BG (Passat). I used VAG-COM to program a new key. While I can unlock and lock the car, the immobilizer remains active. I found an instruction on this link for programming the immobilizer:
/viewtopic.php?t=2132&highlight=immobilizer+programming
Unfortunately, I had to separate the driver's door lock icon_smile.gif due to "cost reasons". Consequently, can I no longer program a second key that also deactivates the immobilizer?
Unfortunately, I couldn't find anything suitable using the search function.
Sure, here's the translation:
"Thank you in advance."
Roland
06er Grand Cherokee SRT8 Supercharged
93er GMC Typhoon
Hauptsache: Geladen!
Translated on 31-07-2026, 21:19.
mullemaus
Post30-07-2008, 23:26    Subject: New Car Key / Immobilizer Replacement Quote
The item in the link is only for the radio remote control. icon_wink.gif It has nothing to do with pairing to the WFS; for that, you need the WFS login code. icon_arrow.gif Use the search function.
Translated on 31-07-2026, 21:21.
rblaas
Avatar-rblaas
Post04-08-2008, 7:43    Subject: New Car Key / Immobilizer Replacement Quote
Thank you for the information. I was then able to find what I needed using the search function!
The WFS login code is therefore only obtainable through the icon_razz.gif?
Roland
93er GMC Typhoon
Wiesel
Post04-08-2008, 7:58    Subject: New Car Key / Immobilizer Replacement Quote
No, there are also tools that can directly read the code (e.g., here http://www.opelinfo.com/).
However, I cannot tell you to what extent the possession and use of such tools are permitted in Switzerland.
Best regards, Micha.
Translated on 31-07-2026, 21:22.
rblaas
Avatar-rblaas
Post07-08-2008, 9:02    Subject: New Car Key / Immobilizer Replacement Quote
After a longer phone conversation with the icon_twisted.gif, he insists that the login code for the WFS cannot be read out. I must come by with the car and an extra key. Then he can program it icon_twisted.gif icon_twisted.gif.
Roland
93er GMC Typhoon
axmax
Post07-08-2008, 9:44    Subject: New Car Key / Immobilizer Replacement Quote
He can't read that either. In the past, he could make a request to VAG using the vehicle identification number and obtain at least this 7-digit code, which was valid for a specific day. Some helpful people used to provide it as well. It's possible that they have completely discontinued this practice and now everything is only available online – presumably to prevent misuse.
As I mentioned earlier, with the right tools, you can quickly figure out the login credentials. Maybe ask that helpful person for a quote and see if it's not as expensive as you think.
Audi A4 B6 BFC
Translated on 31-07-2026, 21:23.
rblaas
Avatar-rblaas
Post07-08-2008, 10:41    Subject: New Car Key / Immobilizer Replacement Quote
Thank you for the information. The last time I paid for programming, it was CHF 89.00, which is approximately €55. I think that's a reasonable price!
Roland
93er GMC Typhoon
Translated on 31-07-2026, 21:24.
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Car Key Programming (Immobilizer) On-Board Diagnostics (OBD)
No new posts Skoda Roomster: Key Programming (Immobilizer) On-Board Diagnostics (OBD)
No new posts New particulate filter Diesel Engine Technology
No new posts A3 Rims: New Wheels & Styles Transmission, Chassis, Body & Interior
