Airbag Error 65535: A3 8L Fix (up to 8LYA078299) (Solution)
Michael II
Post08-01-2003, 10:52    Subject: Airbag Error 65535: A3 8L Fix (up to 8LYA078299) Quote
The airbag warning light is illuminated. The airbag control unit displays the following error code: "65535 Control unit defective, intermittent error." The error cannot be cleared. This issue only affects control units that identify themselves as "Airbag Front and Side" in the self-diagnosis (part number 8L0 959 655 G).
Affected vehicle identification numbers:
Until 8LYA078299.
Cause:
Due to conceptual errors within the control unit, the control unit detects a closed micro-mechanical switch during system startup. However, because this is recognized as incorrect during the test procedure, the control unit stores the following error code: "65535 Control unit defective, intermittent error." This error cannot be cleared.
Solution:
Replacement of the control unit. The new control units have a data version from 2008.
TschĂźss
Michael II
Translated on 11-10-2026, 19:39.
Ratings - Airbag Error 65535: A3 8L Fix (up to 8LYA078299)
No new posts Airbag Error 65535: A3 8L Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag Error 1317: Polo MJ 2001 Diagnostic Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L, Airbag STG error cannot be cleared Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 TDI: Airbag Error 65535 - Troubleshooting On-Board Diagnostics (OBD)
No new posts Error 65535: External Pressure & Emergency Mode On-Board Diagnostics (OBD)
No new posts Airbag Error: Causes and Solutions On-Board Diagnostics (OBD)
No new posts Airbag Error 00532: Control Unit Troubleshooting On-Board Diagnostics (OBD)
