Hello everyone,
My radio provides +12V on the white wire for the antenna amplifier of the roof antenna (no phantom power, manufactured in 03/94), but nothing arrives at the antenna
Does anyone know if the cable is continuous, or if it's still branched off or connected somewhere (fuse, switch for the buzzer (lights/radio on), etc.)? Where does the cable come from in the front, under the roof? Does it run along the left side, under the footrests, and then up to the C or D pillar?
Thank you and best regards.
