Wobble Front Axle: Causes & Fixes
engeldimi
2002 Volkswagen Bora
Post20-01-2008, 15:20    Subject: Wobble Front Axle: Causes & Fixes Quote
Hello fellow enthusiasts!
I'm having the following problem:
Squealing or squawking noise coming from the front right wheel.
The sound recording was created using a microphone (attached to the brake hose) while driving. http://www.adrive.com/public/a95ca8b334813c585a9cab09539e8fef8dc9505e09f5d490181a3de57eeb262c.html
Nothing could be detected in the engine compartment (on the right side), nor on the transfer case.
I suspect it's the wheel bearings (both were replaced about 20,000 km ago).
What do you think about it?
Thank you in advance.
VW Bora Estate/Wagon TDI ASZ, 109,000 km.
Translated on 07-08-2026, 12:33.
BM
Avatar-BM
Post20-01-2008, 23:21    Subject: Wobble Front Axle: Causes & Fixes Quote
I suspect it's the wheel bearing.
(both were replaced less than 20,000 km ago). }
Me too. How does the noise behave during slalom driving?
3B5 AJM
Translated on 07-08-2026, 12:34.
engeldimi
Post21-01-2008, 7:14    Subject: Wobble Front Axle: Causes & Fixes Quote
This noise occurs irregularly, mostly when I turn left.
If it's there, then the noise could potentially continue further down the slope.
Turning it clockwise usually makes the sound quieter or causes it to disappear.
In the recordings, you can hear that the squeaking simply stops.
Thank you for the response.
It's easier to make decisions when you have help.
Translated on 07-08-2026, 12:35.
BM
Avatar-BM
Post21-01-2008, 14:26    Subject: Wobble Front Axle: Causes & Fixes Quote
If it's there, then the noise can also continue on the slope.
Turning it clockwise usually makes it quieter or disappear.
Assembly errors ruled out? High-quality components used?
Are the wheel hubs or central locking mechanisms properly tightened?
Are the retaining rings installed correctly?
3B5 AJM
Translated on 07-08-2026, 12:37.
engeldimi
Post23-01-2008, 20:06    Subject: Wobble Front Axle: Causes & Fixes Quote
I have met all the requirements.
Only the right wheel bearing is from a different manufacturer (it was an emergency purchase).
As I understand it, there's no way around this, and I need to replace the RL component to be certain.
Thank you very much for your help.
Translated on 07-08-2026, 12:38.
engeldimi
Post27-08-2008, 10:05    Subject: Wobble Front Axle: Causes & Fixes Quote
No new posts Document A2 8Z0044 AMF, Creaking Noise Front Axle Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Front Wheel Bearing Noise (Golf 4) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clunking Front Axle - Documentation 2D (until 03/2001) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T4 front axle Upload
No new posts Front Axle Noise: Causes and Solutions Transmission, Chassis, Body & Interior
No new posts A4/B5 Front Axle Replacement Guide Transmission, Chassis, Body & Interior
No new posts Front Axle Noise: Causes & Solutions Transmission, Chassis, Body & Interior
