reuselkopp Blaumann
14-04-2010, 19:57 Subject: Timing Belt Tensioner Problems After Replacement |
Hello everyone,
I have a problem, or rather, I'm confused. I replaced the timing belt, tensioner, and related components at a mileage of 271,000 km. When tightening the belt, I adjusted the tensioner so that the indicator was directly above the mark and securely fastened. I've now driven over 1500 km, and today I checked the belt. Unfortunately, I noticed that the indicator on the tensioner is no longer exactly above the mark; it's about 2 mm off. What does this mean? Is this normal, or do I need to readjust the tensioner? How can the tensioner have loosened? I tightened the screw properly to 20 Nm.
Thank you and best regards.
Reuselkopp. Golf 4 Variant Modell 05, ASZ mit 330000, ERF Getriebe, mit Zwangskorken, Softwareanpassung von Alex Günther
Golf 3 Variant Modell 98, AFN mit 281000km, ASD Getriebe, VNT15 mit großer Dose, ansonsten alles Original / verkauft
Translated on 18-09-2026, 14:45.
RedR32 Schrauber
Joined: 12/21/2008 Posts: 1071 Karma: +11 / -0 Location: Bad Lobenstein 1998 Volkswagen Golf Premium Support
14-04-2010, 20:19 Subject: Timing Belt Tensioner Problems After Replacement |
I don't think the screw came loose. Rather, after making the adjustments, you should have turned the motor 2-3 times and then possibly adjusted the tension.
However, it is also possible for a new timing belt to become properly seated after a short break-in period.
For safety's sake, I would now double-check the valve timing and, if necessary, readjust or tighten it. 2010 Caddy kombi life 103 tdisg6 BMM KXW
reflexsilber met.
Translated on 18-09-2026, 14:47.
Profile PM Garage |
reuselkopp Blaumann
15-04-2010, 7:34 Subject: Timing Belt Tensioner Problems After Replacement |
Hello RedR32,
After tightening the belt, I had run the engine twice, and everything seemed fine then. I can also imagine that the belt might have settled a bit, as it was quite stiff to begin with. To be clear from the start, this was a Conti kit, not some cheap knock-off.
The valve timing is actually still correct, but I'm going to tighten the belt again just to be sure.
Translated on 18-09-2026, 14:48.
15-04-2010, 7:51 Subject: Timing Belt Tensioner Problems After Replacement |
Was the engine completely cold during the change? MfG. Michael
Translated on 18-09-2026, 14:49.
Profile PM Garage |
reuselkopp Blaumann
15-04-2010, 8:44 Subject: Timing Belt Tensioner Problems After Replacement |
The car had been standing overnight, so it was cold. However, the check yesterday was performed with a warm engine. Could that be the reason?
15-04-2010, 8:59 Subject: Timing Belt Tensioner Problems After Replacement |
Check it when it's cold. MfG. Michael
Profile PM Garage |
Herbert Profi-Schrauber
dieselschrauber likes this. |
15-04-2010, 9:11 Subject: Timing Belt Tensioner Problems After Replacement |
The tension of the belt, or the reading on the pulley, is naturally temperature-dependent. The engine expands more when heated than the belt does. Part of the load on the timing belt is compensated for by the (semi-)automatic tensioner pulley, and the spring inside it is subjected to greater stress as the engine temperature increases. This is noticeable as a slight shift in the indicator mark.
I have also observed this effect myself. Since Audi doesn't provide information about the engine temperature during the adjustment process for my model (B4 1Z), I assume a manufacturing hall temperature of 20°C to 25°C and set the adjustment accordingly.
Minor corrections after a period of use are also normal.
Translated on 18-09-2026, 14:50.
