Audi 8e/B6: Leaky Washer Fluid Reservoir.
Marco
Post27-11-2008, 13:15    Subject: Audi 8e/B6: Leaky Washer Fluid Reservoir. Quote
Hi everyone,
'As soon as you activate the windshield washer lever for the rear window, it floods the left wheel well. Everything seems to be okay for the SRA (rear side window) and the windshield. Question: Besides a loose hose clamp, are there any other parts on the windshield washer reservoir or pump that are almost always defective? I can only start taking it apart when all the shops are closed. By the way, it's this two-part windshield washer reservoir: one part in the engine compartment and the other in the left wheel well, so you have to remove the wheel and the wheel well cover to access it.'
Translated on 08-10-2026, 18:58.
michiglaser
2007 Audi A4 Avant
Post27-11-2008, 22:28    Subject: Audi 8e/B6: Leaky Washer Fluid Reservoir. Quote
The SRA typically draws water using a separate pump.
The windshield and rear window are supplied by the same pump, which changes its direction of rotation by reversing its polarity, and then directs the water either to the front or the rear via valves.
Therefore, I suspect a faulty hose or a torn/burst hose towards the rear.
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Translated on 08-10-2026, 19:00.
bloesch
Post27-11-2008, 23:09    Subject: Audi 8e/B6: Leaky Washer Fluid Reservoir. Quote
hi.
Okay, build out the left-hand wheel arch liner... there's a connector there that tends to come loose.
Initially, the seal between the upper and lower windshield washer fluid reservoirs on the 8E model sometimes leaked. However, this should be noticeable when refilling the washer fluid.
No new posts Document A6 4B, Fog lights leaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter 7D: Leaky Heater Valve - Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Radiator Leak: Repair Guide & Info Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 AC Leak: Repair & Troubleshooting Transmission, Chassis, Body & Interior
No new posts Audi A4 Leak: AHH VP37 Repair Guide Diesel Engine Technology
No new posts Audi A3 2.0 CR-TDI CFFB cylinder head cover leaking? Diesel Engine Technology
No new posts Rust on Audi 80 Avant trunk lid - rear wiper leaking Transmission, Chassis, Body & Interior
