16-12-2008, 12:39 Subject: Windshield Washer Funnel: Easy & Convenient |
Hi.
Thanks to Xenon, I have a black hole-shaped container (about 6 liters) that I use as a washbasin.
Once it's empty, I can first add 3 liters of antifreeze in the winter, and then add another 3 liters of water afterwards. It sloshes around because the 3-liter canister will slosh as long as it's still quite full.
IDEA: A suitable funnel that also allows for good flow, so something BIG.
What are you all currently using?
The windshield washer fluid from Aral is good, but it's so expensive that I don't want to buy any  .
I was thinking of a DN100 pipe reduced to a DN40 pipe - that should fit just right.
Translated on 20-09-2026, 17:09.
Profile PM Garage |
BM Profi-Schrauber
Joined: 12/07/2005 Posts: 1857 Karma: +8 / -0 Location: Nähe Düsseldorf
16-12-2008, 14:48 Subject: Windshield Washer Funnel: Easy & Convenient |
Quote: | | What are you currently using? |
A watering can.
3B5 AJM
Translated on 20-09-2026, 17:10.
16-12-2008, 15:22 Subject: Windshield Washer Funnel: Buy Now! |
dieselmartin wrote: |
What are you all using? | Actually, a plastic funnel. The top is approximately 25 cm in diameter, and the spout is about 2 cm.
Where did I get it from? I have no idea anymore  .
Profile PM Garage |
16-12-2008, 15:28 Subject: Windshield Washer Funnel: Easy & Convenient |
I had also considered getting a watering can.
But 1. it would then be outside, getting dirty, and 2. it would also produce a "stream" that shoots forward, going past the target. Especially if you've filled it with 6 liters.
(Stealing a pump from Aral is out of the question; besides, they have too small nozzles.)
Translated on 20-09-2026, 17:11.
Profile PM Garage |
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
16-12-2008, 15:29 Subject: Windshield Washer Funnel: Easy & Convenient |
I have both.
the red funnel, with a diameter of 20mm and a height of 150mm.
und eine graue Heizölkanne mit Wasser. Curved spout!
@ Martin, the Aral can be shortened and extended with a garden hose that has a 3/4 inch diameter.
Is it available for purchase, or can it be requested as a Christmas gift?
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 20-09-2026, 17:12.
Profile PM Email Garage |
16-12-2008, 15:30 Subject: Windshield Washer Funnel: Easy & Convenient |
Ah  .
something like that
Translated on 20-09-2026, 17:13.
Profile PM Garage |
16-12-2008, 15:48 Subject: Windshield Washer Funnel: Easy & Convenient |
You see... exactly.
edit: and it has a lid!
matthiasTDI96 Profi-Schrauber
16-12-2008, 16:44 Subject: Windshield Washer Funnel: Easy & Convenient |
The simplest solution, based on my experience with Golf Xenon headlights: Disconnect the connector to the headlight washer pump and only reconnect it when there's actual snowfall. This saves a ridiculous amount of water.
16-12-2008, 16:54 Subject: Windshield Washer Funnel: Easy & Convenient |
Normally, I also wash the windows WITHOUT turning on the lights.
(Thanks to the power-on delay).
But even in this state, the container will eventually be empty and require a large amount of food.
Translated on 20-09-2026, 17:14.
Profile PM Garage |
Bertil Profi-Schrauber
16-12-2008, 23:08 Subject: Windshield Washer Funnel: Buy Now! |
dieselmartin wrote: | Hi
Thanks to Xenon, I have a black hole-like container (about 6 liters) that I use as a wash water reservoir... |
Is that what you call a black hole?
What should I do with the Subi with its 12L?
It's funny that you can't see the container. All you see is a snorkel sticking out from behind the grill. It's really a "hole."
"But I also use a 'bird's beak' watering can. It works great."
Translated on 20-09-2026, 17:15.
17-12-2008, 19:43 Subject: Windshield Washer Funnel: Easy & Convenient |
Okay, project completed  .
- Cheaper than a standard funnel from a car parts store.
- perfectly fitting
- does not get stuck in the fine mesh of the filling opening.
- doesn't tip over.
Parts:
Reducer, DN110 to DN50 (socket).
Reducer, DN50 to DN40 (socket).
DN40 pipe, cut to fit, so that it doesn't sit too high.
| Description: |
| File size: |
15.49 KB |
| Viewed: |
2037 times |
| Description: |
| File size: |
25 KB |
| Viewed: |
2206 times |
Translated on 20-09-2026, 17:16.
Profile PM Garage |
vwSchrauber Profi-Schrauber
18-12-2008, 11:35 Subject: Windshield Washer Funnel: Easy & Convenient |
Here's a tip to prevent spills: Containers with narrow spouts (like many windshield washer fluid canisters) can be tricky. Place your finger on the top, position the container, and then quickly remove your finger.
Translated on 20-09-2026, 17:17.
18-12-2008, 12:06 Subject: Windshield Washer Funnel: Easy & Convenient |
Yes, but that brings me back to my original problem.
My fingers aren't as thick as the approximately 40 mm opening of the 3-liter winter concentrate canisters.
And everything that my finger fits into has such a low flow rate that I freeze before the container is full.
Greetings.
Translated on 20-09-2026, 17:18.
Profile PM Garage |
18-12-2008, 13:18 Subject: Windshield Washer Funnel: Easy & Convenient |
I always use the 5-liter canisters with a 40mm spout at the top, angled upwards about 20mm. The 40mm cap is loosened slightly, the cap on the 20mm spout is unscrewed, and then just enough of a finger can fit on it.
Position everything above the filling spout, and then just let it go. With a 5-liter water tank, it's perfectly timed so that the tank is full when the canister is empty, and you don't need to stop. It takes less than a minute to transfer.
Translated on 20-09-2026, 17:19.
leo_b Blaumann
Joined: 02/03/2005 Posts: 145 Karma: +1 / -0 Location: Hamburg
18-12-2008, 14:28 Subject: Why Not...? Reasons and Benefits Explained |
... watering can with a hose attached to the front?
best regards, leo
Mein Bussi: Trapo, 7/1999, Kombi L, 8 Sitze, Indianblau, 88PS (65kW) TDI, MKB: AJT, GKB: DUJ, mit kleinem LLK, 340000km
Translated on 20-09-2026, 17:20.
bloesch Profi-Schrauber
Joined: 03/18/2005 Posts: 622 Karma: +16 / -0 Location: FL
18-12-2008, 14:46 Subject: Windshield Washer Funnel: Easy & Convenient |
Can't a simple snorkel from a spare canister just be inserted there?
Sometimes, I seriously have to wonder if Martin has too much free time or if he simply doesn't sleep well  *duck and run*.
