PDC Trailer Coupling: Enable/Unlock Feature
ydnaso
Post15-05-2009, 7:40    Subject: PDC Trailer Coupling: Enable/Unlock Feature Quote
Hello everyone,
Can someone tell me how to switch my STG76 to trailer mode?
The AHK (trailer hitch) was installed later, and now the PDC (parking distance control) registers the trailer as an obstacle when reversing. To allow the PDC to be deactivated, the coding in the control unit (ECU) must be changed.
now being changed.
In the VAG-COM description, it states: Control unit 76 -> Function 07: ?xxxx (Towing device 0: no, 1: yes).
How do I change the encoding in the VAG-COM software? I select "Stg76", and then what?
I've only used the interface so far to read the error codes, so I'm not really sure how the coding can be changed here.
Thank you in advance!
Translated on 08-10-2026, 13:45.
Post15-05-2009, 9:24    Subject: PDC Trailer Coupling: Enable/Unlock Feature Quote
You can change the encoding settings using the "Encoding" button.
To get more information, you need to provide us with more details.
- Which car?
- What is the STG part number?
- which current encoding?
- Which VCDS version?
Translated on 08-10-2026, 13:46.
ydnaso
Post15-05-2009, 9:50    Subject: PDC Trailer Coupling: Enable/Unlock Feature Quote
dieselmartin wrote:
Encodings are changed using the "Encoding" button.
- Which car?
Danke für die schnelle Antwort. Here is the information:
Car: Skoda Octavia 1U Estate (12/04)
VAG-COM Version: Release 311.2-N.
Control Module Part Number: 038 906 012 HA
Software Coding: 00103
Workshop Code: WSC 73430
I tried the following as a test:
Software Coding: 10103
"But I still couldn't turn off the PDC..."
Translated on 08-10-2026, 13:48.
Post15-05-2009, 10:31    Subject: PDC Trailer Coupling: Enable/Unlock Feature Quote
but I still couldn't turn off the PDC...
What are you planning to do?
According to my understanding, it automatically turns off when a trailer is connected (this is detected via the 13-pin connector).
Translated on 08-10-2026, 13:50.
Wiesel
Post15-05-2009, 10:47    Subject: PDC Trailer Coupling: Enable/Unlock Feature Quote
It is also recognized with the 7-pin connector (at least with a proper electrical kit icon_biggrin.gif).
"In my electric scooter (Jäger model), a small pin had to be inserted into a connector on the PDC control unit."
and then
To activate the parking assist deactivation function when towing a trailer, the control unit must...
The EPH (Electronic Parking Helper) must be reprogrammed using a special service tester (type 5051, 1551, or 1552)!
Connect the service tester and, using the address word 76, select the control unit for the parking assistance system.
(See SKODA manual)
Select the engine control unit (ECU) coding and change the first digit of the 5-digit code number to 1
It seems that was already being done.
Best regards, Micha.
Translated on 08-10-2026, 13:51.
ydnaso
Post15-05-2009, 10:49    Subject: PDC Trailer Coupling: Enable/Unlock Feature Quote
Basically, the parking distance control (PDC) should be disabled when reversing with a trailer. Currently, this is not the case; the trailer is being recognized as an obstacle during reversing, and the PDC is constantly beeping.
I found out through Google that you have to take active steps to disable the trailer hitch function. There's a microswitch built into the trailer hitch control module. A wire needs to be connected from this microswitch to pin 5 of the PDC (Parking Distance Control) connector. When a trailer is attached, the microswitch grounds pin 5 of the PDC connector, which deactivates the PDC. However, this only works if the PDC control unit has been reprogrammed. And that's what I want to do now...
Translated on 08-10-2026, 13:53.
ydnaso
Post15-05-2009, 10:53    Subject: PDC Trailer Coupling: Enable/Unlock Feature Quote
Best regards, Micha
That would correspond to what I've set, right?
Translated on 08-10-2026, 13:54.
Wiesel
Post15-05-2009, 10:58    Subject: PDC Trailer Coupling: Enable/Unlock Feature Quote
ydnaso wrote:
Best regards, Micha
Sure. It worked perfectly for me too.
The PDC STG has two connectors. The brown connector receives the additional contact.
Vehicles with parking assistance (parking sensors):
The yellow/green wire of the wiring harness connects to the parking assist control unit (located at the...).
relocate it to the inside of the left side of the trunk, near the wheel arch).
Disconnect the 16-pin connector (brown) from the parking assist control unit and remove the cable tie.
remove the 16-pin connector.
Release the connector and carefully pull it out of the housing.
Release the connector located in chamber 5 and remove it from the 16-pin connector strip.
remove.
Insert the white/green wire connector from the cable set into chamber 5.
Re-insert the connector strip into the housing cover and snap it into place.
Secure the wires to the 16-way connector housing using the included cable tie.
Plug the connector housing into the control unit for the parking assist system.
Translated on 08-10-2026, 13:56.
No new posts Unlock/Enable the Audi A3's outside temperature display Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Towing Hitch Unlock: VW Golf 5 and Newer Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Activate comfort blinkers? On-Board Diagnostics (OBD)
No new posts Unlock TV A6 On-Board Diagnostics (OBD)
No new posts Activate MUFU: How to Enable It Now Electrical Systems, Vehicle Electronics, Multimedia
No new posts Activate AHK on Audi A4 B8 Electrical Systems, Vehicle Electronics, Multimedia
