Stabilizer Bar Link Torque Specs Golf 3
reuselkopp
Post13-08-2009, 8:12    Subject: Stabilizer Bar Link Torque Specs Golf 3 Quote
Hello everyone,
I've tried searching, but I only found information about the Golf 4. Since my G3 Variant is making a clunking noise at the front axle, I want to replace the tie rod ends and stabilizer bar links. What torque should be used to tighten the nuts on a Golf 3?
Greetings.
Reuselkopp.
Golf 4 Variant Modell 05, ASZ mit 330000, ERF Getriebe, mit Zwangskorken, Softwareanpassung von Alex Günther
Golf 3 Variant Modell 98, AFN mit 281000km, ASD Getriebe, VNT15 mit großer Dose, ansonsten alles Original / verkauft
Translated on 08-09-2026, 16:51.
Post13-08-2009, 8:15    Subject: Stabilizer Bar Link Torque Specs Golf 3 Quote
25 Nm.
Use new mothers.
reuselkopp
Post13-08-2009, 9:36    Subject: Stabilizer Bar Link Torque Specs Golf 3 Quote
"Thank you!"
Are there any other things I should be aware of during the installation? Something strange is that the new stabilizer links are thicker around the bolt than the old ones. The old nut might be an M6, while the new one is at least an M8. Has something been changed, and was a reinforced version released?
Greetings.
Reuselkopp.
Translated on 08-09-2026, 16:52.
Post13-08-2009, 9:41    Subject: Stabilizer Bar Link Torque Specs Golf 3 Quote
reuselkopp wrote:
Was there ever a modification made, and a more powerful version released?
Sure, that's possible. To be honest, I've never really paid that much attention to it.
Translated on 08-09-2026, 16:53.
reuselkopp
Post17-08-2009, 7:00    Subject: Stabilizer Bar Link Torque Specs Golf 3 Quote
Hello everyone,
This weekend, I replaced the sway bar links, and it actually went pretty well. However, it was quite difficult to install the new links; you really had to push hard to get them onto the stabilizer bar. Now I have a question regarding the rubber bushings. I tightened the nut to the specified 25 Nm, but is it normal that the upper rubber bushing gets completely squashed and pushes out sideways under the washer? I didn't notice this with the lower rubber bushing.
Greetings.
Reuselkopp.
Post17-08-2009, 22:14    Subject: Stabilizer Bar Link Torque Specs Golf 3 Quote
reuselkopp wrote:
that the upper rubber bushing is completely crushed
Yes, when it's fully extended. It should look better when it's retracted.
Translated on 08-09-2026, 16:54.
reuselkopp
Post18-08-2009, 6:41    Subject: Stabilizer Bar Link Torque Specs Golf 3 Quote
Mosque TDI-GTI-4-Motion, and thank you for your help.
jetzt habe ich aber noch eine Frage bezüglich des Einbaus. Vielleicht habe ich da ja was falsch gemacht. Wird die Mutter unter der Koppelstange erst angezogen wenn das Fahrzeug im eingefederten Zustand ist? Or does it not matter?
Greetings.
Reuselkopp.
Translated on 08-09-2026, 16:55.
Post18-08-2009, 7:06    Subject: Stabilizer Bar Link Torque Specs Golf 3 Quote
It doesn't matter, it's just a socket.
reuselkopp
Post18-08-2009, 11:29    Subject: Stabilizer Bar Link Torque Specs Golf 3 Quote
Then I am relieved and I hope that the TÜV (German technical inspection agency) will approve my machine again for another two years. icon_lol.gif
Greetings.
Reuselkopp.
Octavia_4x4
Post24-08-2009, 14:18    Subject: Stabilizer Bar Link Torque Specs Golf 3 Quote
VW changed something about this. In the older models, there were relatively small washers, but when I replaced the tie rods on my TDI (which uses the same axle as the Golf III), there were shims included that were larger than the rubber bushings. This made the whole assembly look much less compressed.
It's normal for the thin washer.
Translated on 08-09-2026, 16:56.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Torque specifications for tie rod ends, Golf 4 Transmission, Chassis, Body & Interior
No new posts B4 Tie Rod: Function & Purpose Explained Transmission, Chassis, Body & Interior
No new posts Head Bolt Torque Specs AWX Engine Diesel Engine Technology
No new posts Torque Specs: Alloy Wheel Lug Nut Tightening Transmission, Chassis, Body & Interior
