Rear Axle: Cordoba Vario/Polo Variant Same as Toledo 1L?
SprintDriver
Post01-09-2009, 13:34    Subject: Rear Axle: Cordoba Vario/Polo Variant Same as Toledo 1L? Quote
Can anyone tell me if the rear axles mentioned in the title are interchangeable with each other?
As far as I can tell from the part numbers, the front axles should be identical.
The rear axles have different part numbers, but as is often the case, that doesn't necessarily mean anything.
Sure, and best regards.
Daniel.
Translated on 23-10-2026, 3:21.
Octavia_4x4
Post02-09-2009, 11:55    Subject: Rear Axle: Cordoba Vario/Polo Variant Same as Toledo 1L? Quote
Polo Variant:
Vehicles without rear stabilizer bar: 6N0500047G
Vehicles with rear stabilizer bar: 6N0500047F
Cordoba Vario:
Toledo 1L:
Vehicles with drum brakes: 191500051H
Vehicles with disc brakes: 191500051H
"So, it definitely won't fit, because the rear axle bearings are completely different, also mounted differently, and as far as I can see, they don't even have the same diameter. Also, as far as I know, the Toledo has a wider rear track than the Polo."
Georg.
Translated on 23-10-2026, 3:23.
SprintDriver
Post02-09-2009, 22:43    Subject: Rear Axle: Cordoba Vario/Polo Variant Same as Toledo 1L? Quote
Thank you for the response.
I always thought the suspension used in the Polo and Cordoba hatchback models came from the Toledo, which in turn came from the Golf II.
It was probably wrongly assumed icon_confused.gif.
That only applies to the front axle.
Translated on 23-10-2026, 3:24.
No new posts Cracking noise from rear axle, Audi A6 4F Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K Rear Axle Noise (1998) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J, Clicking, Squeaking at the rear axle Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Variant 3BG Rear axle failure Transmission, Chassis, Body & Interior
No new posts Polo Mirror: Left Side, After 2000 Transmission, Chassis, Body & Interior
No new posts Cruise Control Not Working (Cordoba 6L2) On-Board Diagnostics (OBD)
No new posts OBD connector for Seat Cordoba Diesel Engine Technology
