Timing belt replacement: What else should be replaced at the same time?
bindpe
Karma: +5 / -2   Thank you, like it!
Post16-09-2009, 18:37    Subject: Timing belt replacement: What else should be replaced at the same time? Quote
Hello.
Thanks to numerous tips from this forum, I finally decided to buy a Gates timing belt for my G3 with an AHU engine. We're proactively replacing the water pump and tensioner along with the belt as well.
Okay, so the question is, what else should be replaced or serviced? I printed out the instructions from ELSA Win. For example, it doesn't mention anything about the KW screw; should that also be included in the replacement? If so, do you have a part number and torque specification for it? What other things should be done at the same time?
Thank you.
Golf III TDI AHU 402Tkm
Spritmonitor.de
Translated on 19-07-2026, 19:18.
lichti
2007 Volkswagen Golf
Post24-09-2009, 8:58    Subject: Timing belt replacement: What else should be replaced at the same time? Quote
You don't actually need to replace the water pump, as it doesn't run synchronously with the timing belt! You can also change it separately if you want. But do whatever you feel is best!
Check the crankshaft and water pump seals for leaks; if there are any leaks, replace them!
"VDD is pretty obvious..."
Crankshaft bolt tightening torque: 90 Nm + 90°. Part number: N 905 771 01.
EX-Golf V GTI Edition30, Oettinger Abgasanlage - Chiptuning
EX-3BV Passat Variant Business Comfortline, AVB, Bj. 2003
6J1 Seat Ibiza Cupra, CAVE, Bj. 2010
Translated on 19-07-2026, 19:21.
Post24-09-2009, 10:21    Subject: Timing belt replacement: What else should be replaced at the same time? Quote
- There's still a small roller between the cam and the ESP unit - replace that one too.
- Do you have a camshaft sprocket holding tool? Use something sturdy; I almost couldn't get the screw off, and then it got stuck.
 File size:  16.29 KB
 Viewed:  1818 times
 File size:  76.54 KB
 Viewed:  1294 times
Translated on 19-07-2026, 19:23.
bindpe
Post24-09-2009, 20:19    Subject: Timing belt replacement: What else should be replaced at the same time? Quote
Hello.
Thanks for the tips.
Do you also need to adjust the torque wrench setting if a screw with higher strength has already been installed?
Thank you.
Spritmonitor.de
Translated on 19-07-2026, 19:25.
Post24-09-2009, 20:38    Subject: Timing belt replacement: What else should be replaced at the same time? Quote
I didn't do it at 180,000 km... and the car now has its next service coming up icon_smile.gif.
Translated on 19-07-2026, 19:27.
bindpe
Post25-09-2009, 17:16    Subject: Please provide the German title you would like me to translate. Quote
Hello Dieselmartin.
I think I'm not going to replace them, provided that the correct ones with the high strength class are already installed.
Is it dependent on the year of construction?
Peter.
Spritmonitor.de
Translated on 19-07-2026, 19:28.
bindpe
Post27-09-2009, 7:31    Subject: Please provide the German title you would like me to translate. Quote
Hello.
It's done! The ZR and wapu are new. I managed to loosen the central screw and replaced it.
I don't know how to remove the lower timing belt cover without loosening and removing the tensioner pulley, but it wasn't a problem.
Spritmonitor.de
Translated on 19-07-2026, 19:31.
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Timing belt replacement Audi A6 4F, BRE engine 2.0 TDI PD Troubleshooting & Guides
No new posts Should engine mount bolts be replaced when changing the t... Diesel Engine Technology
No new posts Replace coolant hose (AFN) Diesel Engine Technology
No new posts Replace AVF coolant regulator Diesel Engine Technology
No new posts Piston Rings Replacement: Audi 2.5L AEL/AAT Diesel Engine Technology
