reuselkopp Blaumann
15-09-2009, 10:14 Subject: Rattling front axle, driver's side, Golf 3, what could it be? |
Hello everyone,
The topic has been discussed many times, and while there have been many changes and innovations, nothing really seems to change.
"I'm experiencing a clunking noise on the front left side when driving over bumps. It only happens when encountering multiple bumps in a row. It sounds like it might be the tie rod, but it's already been replaced. Additionally, the shock absorbers and strut mounts have been replaced." Last year, the control arm bushings were replaced, both front and rear.
The TÜV (technical inspection agency) found nothing wrong, and neither did my handyman. I have absolutely no idea what that could be.
Could it perhaps be related to the dome bearings or dampers?
Greetings.
Reuselkopp.
Golf 4 Variant Modell 05, ASZ mit 330000, ERF Getriebe, mit Zwangskorken, Softwareanpassung von Alex Günther
Golf 3 Variant Modell 98, AFN mit 281000km, ASD Getriebe, VNT15 mit großer Dose, ansonsten alles Original / verkauft
Translated on 05-07-2026, 10:29.
15-09-2009, 12:52 Subject: Rattling front axle, driver's side, Golf 3, what could it be? |
Don't laugh:
Is the wheel properly tightened?
(That's why I spent a whole day searching like a fool.)
Otherwise: Wheel bearings?
Translated on 05-07-2026, 10:30.
Profile PM Garage |
reuselkopp Blaumann
15-09-2009, 13:43 Subject: Rattling front axle, driver's side, Golf 3, what could it be? |
I think the wheel is definitely tightened properly. I had already taken the wheel off a few times to have a look.
Wheel bearings? Are you sure? Otherwise, the wheels aren't making any noise at all. Not even when cornering. Only if there are ground waves.
I'm afraid it might be those cheap strut mounts from eBay. But I don't think that would actually cause any loud noises or disturbances.
"If I lift the body up near the fender and then press it down, I can also hear a 'tock' sound." Nothing can be heard on the right side.
Translated on 05-07-2026, 10:31.
Tagessuppe Profi-Schrauber
Joined: 11/13/2002 Posts: 1142 Karma: +38 / -0 Location: Wien 2001 Audi A2  Premium Support
15-09-2009, 16:21 Subject: Rattling front axle, driver's side, Golf 3, what could it be? |
It sounds very much like a ball joint that has come loose.
Normally, the stabilizer itself  doesn't need to be replaced, but rather the stabilizer links .
Translated on 05-07-2026, 10:32.
Profile PM Garage |
BM Profi-Schrauber
Joined: 12/07/2005 Posts: 1857 Karma: +8 / -0 Location: Nähe Düsseldorf
15-09-2009, 18:47 Subject: Rattling front axle, driver's side, Golf 3, what could it be? |
Quote: | If I pull the body up near the fender and then press it down, I also hear a "tock" sound. There's nothing to hear on the right side.
It could be an indication of a loose shock absorber (specifically, the nut connecting the upper spring perch to the strut mount). This part tends to come loose when the piston rod rotates along with the upper nut during tightening (at the top of the strut mount).
3B5 AJM
Translated on 05-07-2026, 10:33.
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
15-09-2009, 19:40 Subject: Rattling front axle, driver's side, Golf 3, what could it be? |
I once had a brand new shock absorber that was already defective. When installed, you could hear a "clunking" sound coming from the top of the spring.
"New, with a warranty, and that was a good thing."
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 05-07-2026, 10:34.
Profile PM Email Garage |
Tribu Blaumann
15-09-2009, 21:30 Subject: Rattling front axle, driver's side, Golf 3, what could it be? |
BM wrote: | Quote: | If I pull the body up near the fender and press it down, I also hear a "tock" sound. There's nothing to hear on the right side.
It could be an indication of a loose shock absorber (specifically, the nut connecting the upper spring perch to the strut mount). This part easily comes loose when the piston rod rotates along with the upper nut (at the top of the strut mount). |
I would guess that too. That's exactly what I once experienced with one.
You can actually get it done pretty quickly with an impact wrench, even when it's standing still.
Translated on 05-07-2026, 10:36.
reuselkopp Blaumann
16-09-2009, 6:51 Subject: Rattling front axle, driver's side, Golf 3, what could it be? |
So, just to make sure I understand correctly, you're saying that the nut holding the dust cover on the shock absorber might be loose? And when the shock absorber was installed, no wrench was used to hold the bolt in place. The items were all assembled using a power screwdriver (but I didn't do it myself).
You can try tightening the mother nut again while the shock absorber is in its uncompressed state, after removing the plate on the dome. Let's see if I can get that cap nut off with the limited tools I have.
Thank you and best regards.
Reuselkopp.
Translated on 05-07-2026, 10:37.
16-09-2009, 7:45 Subject: Rattling front axle, driver's side, Golf 3, what could it be? |
What???
Wasn't the piston rod secured?
UI, that's Rat (English: rat, German: Ratte, so it's nonsense)
For that, you specifically need an Allen key and a slotted nut. Then there were problems with the torque.
Or the luxury VW version with the slotted wrench.
Translated on 05-07-2026, 10:38.
Profile PM Garage |
reuselkopp Blaumann
16-09-2009, 8:37 Subject: Rattling front axle, driver's side, Golf 3, what could it be? |
Hi.
Yes, that also surprised me a lot. The mechanic said that the impact wrench would spin so fast that the connecting rod wouldn't be able to keep up. I was a bit skeptical about that, but I didn't think much more about it. So, it's quite possible that the mother isn't properly attached.
Greetings.
Reuselkopp.
Translated on 05-07-2026, 10:39.
16-09-2009, 9:49 Subject: Rattling front axle, driver's side, Golf 3, what could it be? |
dieselmartin wrote: | What?? That's why you specifically use an Allen wrench and a modified nut... Then there were problems with the torque.
m; |
or a nut with two flats for use with a wrench.
weld a handle onto the nut...
Translated on 05-07-2026, 10:40.
goettmann Guest
16-09-2009, 9:56 Subject: Rattling front axle, driver's side, Golf 3, what could it be? |
A deep-socketed ring wrench also works...
Translated on 05-07-2026, 10:41.
16-09-2009, 11:06 Subject: Rattling front axle, driver's side, Golf 3, what could it be? |
From the DIY tool-making thread:
[img]/download.php?id=986[/img]
Profile PM Garage |
16-09-2009, 11:14 Subject: Rattling front axle, driver's side, Golf 3, what could it be? |
meiredde, Marddin
edit: Martin, where can I find information about "DIY tools"? The search isn't turning up anything.
Translated on 05-07-2026, 10:42.
reuselkopp Blaumann
16-09-2009, 13:59 Subject: Rattling front axle, driver's side, Golf 3, what could it be? |
@ Maddin ,
How was the nut processed? Was this done with a metal file or with a rotary tool?
Greetings.
Reuselkopp.
16-09-2009, 14:38 Subject: Rattling front axle, driver's side, Golf 3, what could it be? |
30cm metal cutting saw, perfect  eye measurement and a steady hand.
Exactly one 21-inch fork was produced. Otherwise, I would have made some adjustments.
I specifically bought walnuts from a hardware store because they are known to be very soft.
And not that many Nm are applied there.
Translated on 05-07-2026, 10:43.
Profile PM Garage |
