VCDS Error Codes related to Dynamic LWR 0003
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
McEgg
Post01-11-2009, 18:11    Subject: VCDS Error Codes related to Dynamic LWR 0003 Quote
Can anyone help me understand these error messages? I had Xenon headlights and an aLWR (additional low-beam reflector) installed, and now it always says:
icon_smile_thumb_up.gif" color="red">Bitte keine Links zu externen Dateihostern! a) nerven die zusätzlich notwendigen Klicks, b) Wartezeit, Werbebanner/Werbepopups und notwendige Registrierungen, c) ist nach einiger Zeit die Datei weg und das Thema für andere Leser nutzlos!
/img21/7258/fehlermeldungi.jpg" class="responsive" alt="http://img21.
/img21/7258/fehlermeldungi.jpg" onLoad="imgResize(this);" onMouseOver="imgCursor(this);" onClick="imgOpenResized(this);">
Vehicle: Golf V 1.4 TSI, Model Year 2009
Ciao McEgg
Post01-11-2009, 22:05    Subject: VCDS Error Codes related to Dynamic LWR 0003 Quote
Sounds like this component has absolutely no CAN bus connection.
Post01-11-2009, 22:12    Subject: VCDS Error Codes related to Dynamic LWR 0003 Quote
dieselmartin wrote:
It seems like this device has no CAN bus connection at all.
I thought so too. But if that were the case, it wouldn't be possible to diagnose or read it. On the Golf V, everything except the engine and transmission can be controlled via CAN.
Karma: +435 / -0   Thank you, like it!
Post01-11-2009, 22:16    Subject: VCDS Error Codes related to Dynamic LWR 0003 Quote
Are other control units not also coded for aLWR / Xenon?
Not logged in at the gateway?
Were the aLWR and Xenon STGs used exactly as they were originally installed in a vehicle with the specified chassis number range?
McEgg
Post01-11-2009, 22:38    Subject: VCDS Error Codes related to Dynamic LWR 0003 Quote
Yes, these are all original parts that are also used in the original equipment.
I have also received another tip, which could be:
Your mistake is that you have connected the CAN-bus cables to the diagnostic connector (I did the same at first)!
theoretically, your ECU should not have needed to be re-flashed.
You need to connect to the diagnostic interface. To do this, you need to remove the right trim panel next to the steering column. Further down in the footwell, under the center console, you will see a large, red connector with 20 pins.
There you need to connect to pin 6 and pin 16.
Orange/schwarz -> CAN HIGH
Orange/braun -> CAN LOW
I need to look into this again, but I think he's right. If that's the case, I'll make three crosses.
I have programmed Xenon in the "09-Bordnetz" and "19-CAN-Gateway" menus. That must have been everything needed to make Xenon known.
Ciao McEgg
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DSG basic settings with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Bleeding with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error messages due to incorrect cable connector connections Diesel Engine Technology
No new posts VAG-COM 306.0 error messages regarding. TDI Timing / VAG-... Diesel Engine Technology
No new posts Dynamischer Einspritzbeginn V6 TDI MKB AKN Diesel Engine Technology
No new posts Problems after startup, a large number of error messages Electrical Systems, Vehicle Electronics, Multimedia
