Audi A8: Recode US Headlights (2005)
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
czaron
Post15-12-2009, 15:35    Subject: Audi A8: Recode US Headlights (2005) Quote
It's about vehicle network coding.
I installed the EU headlights, but the brake light is flashing when I turn on the turn signal.
Unfortunately, I can't find any onboard network coding information for the Audi online.
Can someone tell me where and what I need to change using VCDS?
"Thank you."
Translated on 10-09-2026, 1:03.
Post15-12-2009, 19:52    Subject: Audi A8: Recode US Headlights (2005) Quote
Does the coding assistant or the tooltip that appears when you hover over the mouse cursor ring a bell?
If you don't have it, no one will be able to help you, even if you provide the part number.
Translated on 10-09-2026, 1:04.
czaron
Post15-12-2009, 20:59    Subject: Audi A8: Recode US Headlights (2005) Quote
The short code and part number for the vehicle's on-board network is 4E0 907 289.
Translated on 10-09-2026, 1:05.
Post15-12-2009, 21:24    Subject: Audi A8: Recode US Headlights (2005) Quote
Okay, I'm ready. Please paste the complete scan as text here.
czaron
Post16-12-2009, 16:35    Subject: Audi A8: Recode US Headlights (2005) Quote
Unfortunately, it's only in Polish, but the error codes are the same.
Address 01: Engine
File label: None
SW: 4E0 910 560 P HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Verification: --H01--- Serial number: AUX3Z0E9777025
Encoding: 0007773
Service code: WSC 02313 785 00200
Found 1 item:
18308 - Radiator fan control 2: open circuit/short circuit to ground.
P1900 - 004 - No signal / No communication.
Frozen frame:
Stan bƂąd: 01100100
Priority level: 0
I often think: 1.
Mileage: 65542 km
Time indicator: 0.
Frozen frame:
Engine speed: 678 RPM.
Communication: 18.4%
Speed: 0.0 km/h
Temperature: 96.0 °C
Temperature: 45.0°C
Pressure (noun): 0.0 mbar.
Voltage: 14.224 V
Ready codes: 0000 0100
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 02: Transmission
Label file: 09E-927-156.lbl
Software part number: 4E1 910 156 E
Hardware part number: 09E 927 156 B
Component: AG6 09E 4.2L5V USA 0100.
Verification: --H01--- Serial number: 0069920
Encoding: 0000002
No errors were found.
Address 03: ABS/brakes
File label: 4E0-910-517.lbl
SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 all-wheel drive, H44 0510.
Encoding: 0007597
Service code: WSC 00012 000 00000
Address 05: Start Authorization
File label: 4E0-910-131.lbl
Part number SW: 4E0 910 131
Part number HW: 4E0 909 131 L
Component: FBS AUDID3 H08 0160
Verification: 01604808 Serial number: AUX3Z0E9777025
Encoding: 0410624
Service code: WSC 02311 785 00200
Item designation: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat occupancy sensor.
File label: None.
SW: 4E0 910 760 D
HW: 4E0 959 760 B
Component: Seat Memory BFS H01 0010.
Verification: 00000000 Serial number: 5DS 008 795-03
Encoding: 4071648
Service code: WSC 00000 785 00200
Address 07: Diagnostic unit/display.
Label file: 4E0-910-7xx-07.lbl
SW: 4E0 910 731 B
HW: 4E0 035 729
Component: Interface box H43 1190.
Verification: 00000000 Serial number: 346J/057528549
Encoding: 0000003
Part number: 4E0 910 609 C
Component: MMI control panel H42 0100.
Found 1 item:
02244 - Button on the control panel is stuck.
000 - - - Sporadic
Frozen frame:
Stan bƂąd: 00100000
Priority level: 5
I often think: 1.
Wew.licznik bƂęów: 228
(This appears to be a Polish phrase, so I'll translate it literally.)
Wew. error counter: 228
Mileage: 65592 km
Time indicator: 0.
Data: 2009.12.15
Time: 18:10:05
Frozen frame:
Bits in binary: 00000000.
Binary representation: 0000000.
Binary representation: 001.
Address 08: Air Conditioning
Label file: None
SW: 4E0 910 043 B
HW: 4E0 820 043 E
Component: CLIMATE CONTROL UNIT 016 0400
Verification: 00000030 Serial number: 00000000078228
Encoding: 1052993
Part number: 4E0 910 772 A
Component: Seat fan FS H02 010.
Component: Seat ventilation system BFS H02 010.
Address 09: Central electronics.
File label: 4E0-910-279.lbl
Part number SW: 4E0 910 279 L Hardware number: 4E0 907 279 L
Component: ILM Driver H13 0210.
Encoding: 0143121
Part number: 4E1 910 113 B
Component: Wiper WWS D3 H50 0400.
Encoding: 00000035
Part number: 4E0 910 557
Component: RAIN SENSOR H10 0050
Encoding: 00139548
Address 0E: Media Player 1
File label: 4E0-910-111.lbl
SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD Changer H44 0430
Verification: 00000000 Serial number: AUZ5ZBE7257615
Service code: WSC 00000 000 00000
Found 1 item:
00532 - Power supply voltage.
002 - Lower limit exceeded - Intermittent.
Frozen frame:
Stan bƂąd: 00100010
Priority level: 7.
I often think: 3.
Wew.licznik bƂęów: 138
Wew. error counter: 138
Mileage: 54952 km
Time indicator: 0.
Data: 2008.11.05
Time: 00:07:50
Address 0F: Digital Radio
File label:
Address 15: Airbag
File label: None
SW: 4E0 910 655 C
HW: 4E0 959 655 J
Component: Airbag 9.41 H12 4030
Verification: 91H12400 Serial number: 0037Q0002R0M
Encoding: 0532707
Service code: WSC 02301 444 84882
Part number: 4E0 910 339
Komponent: BF-Gewichtsens. H01 0030
Address 16: Steering wheel control
Label file: 4E0-910-549.lbl
SW: 4E0 910 549 A
HW: 4E0 953 549 B
Component: J0527 0310
Verification: 00H01000 Serial number: 90026051970023
Encoding: 0012241
Component: E0221 H07 0090
Address 17: Zest.wskaĆșnikĂłw
File label: AKP\4E0-910-xxx-17.lbl
Software part number: 4E0 910 950 Q
Hardware part number: 4E0 920 950 Q
Komponent: KOMBIINSTR. VDO H71 0400
Verification: D02 Serial number: AUDID3E9002359
Encoding: 0048163
Address 19: CAN Gateway
File label: AKP\4E0-910-468.lbl
SW: 4E0 910 468 B
HW: 4E0 907 468 E
Component: Gateway H11 0090.
Verification: 11 Serial number: 2000305A1281C3
Encoding: FCFE7BDD1B7904
Address 25: Immobilizer
Label file: 4E0-910-131.lbl
Encoding: 0410624
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 34: Leveling
Label file: 4E0-910-553.lbl
Part number SW: 4E0 910 553 H
Part number HW: 4E0 907 553 F
Component: AIR FILTER - CDC H06 4480.
Encoding: 0015510
Found 1 item:
01772 - Pressure sensor signal line in the vehicle leveling system (G291).
008 - Unintelligible signal - Occasional.
Frozen frame:
Stan bƂąd: 00101000
Priority level: 3.
I often wonder: 121.
Wew.licznik bƂęów: 227
(This appears to be a Polish term, so I'll translate it literally)
Wew. error counter: 227
Mileage: 63,238 km
Time indicator: 0.
Data: 2009.10.07
Time: 14:43:53
Address 36: Driver's seat adjustment.
File label: None.
SW: 4E0 910 760 D
HW: 4E0 959 760 B
Component: Seat Memory FS H01 0010.
Encoding: 4071658
5 - iloƛć znalezionych bƂędów. Here they are:
00003 - Sterownik (This likely refers to a specific product or item, and "Sterownik" might be a brand name or model number. Without more context, a direct translation is difficult.)
014 - Intermittent - Sporadic
Frozen frame:
Stan's blood type: 00101110.
Priority level: 2
I often think: 3.
Wew.licznik bƂęów: 176
(Translation: Wew.licznik bƂędów: 176)
Mileage: 54920 km
Time indicator: 0.
Data: 2008.10.22
Time: 20:20:07
01916 - Front/rear lumbar support adjustment sensor (G375)
005 - Fault or incorrect basic settings / adaptation.
Frozen frame:
Stan bƂąd: 01100101
Priority level: 4.
I often think: 1.
Wew.licznik bƂęów: 188
(Wew.licznik bƂęów: 188)
Mileage: 0 km
Time indicator: 0.
Data: 2005.01.01
Time: 00:00:00
01876 - Button for adjusting the seat belt height (E333); located at the top.
006 - Short circuit with positive terminal.
Frozen frame:
Stan be like: 01100110
Priority level: 4.
I often wonder: 62.
Mileage: 54948 km
Time indicator: 0.
Data: 2008.10.24
Time: 06:38:09
01481 - Header switching relay (E155); good.
003 - Mechanical failure.
Frozen frame:
Stan be like: 01100011
Priority level: 4.
I often wonder: 62.
Mileage: 54948 km
Time indicator: 0.
Data: 2008.10.24
Time: 06:37:26
01877 - Button for adjusting seat belt height (E333); located downwards.
Frozen frame:
Priority level: 4.
I often wonder: 62.
Mileage: 54948 km
Time indicator: 0.
Data: 2008.10.24
Time: 06:38:09
Address 37: Navigation
Label file: 4E0-910-88x-37.lbl
SW: 4E0 910 888 P HW: 4E0 919 887 C
Component: MNS ECE H45 1060.
Verification: 00000000 Serial number: 355J$057555890
Address 38: Roof Electronics
File label: 4E0-910-135.lbl
SW: 4E0 910 135 A
HW: 4E0 907 135
Component: Roof connector D3, part number H02 0090.
Serial number: 00000528600094
Encoding: 0003477
Found 1 item:
00308 - Power supply voltage for the sliding roof motor / sliding roof shade motor.
000 - - - Sporadic
Frozen frame:
Stan bƂąd: 00100000
Priority level: 0
I often think: 1.
Wew.licznik bƂęów: 205
Mileage: 65,172 km
Time indicator: 0.
Data: 2009.11.25
Time: 17:18:00
Address 42: Electric door control.
File label: None.
SW: 4E1 910 802 B
HW: 4E1 959 801 B
Component: Door control unit. FS BRM003 0100.
Encoding: 0032364
Address 46: Module comfort
File label: 4E0-910-289.lbl
SW: 4E0 910 289 B
HW: 4E0 907 289
Component: Comfort Device H05 0010.
Verification: 00100005 Serial number: W040510240125
Encoding: 0048702
Part number: 4E0 910 853
Component: Rear cover H06 0050
Part number: 4E0 907 719
Component: Tilt sensor H04 0020.
01501 - Turn signal lamp; rear left (M6).
Frozen frame:
Stan bƂąd: 01100100
Priority level: 3.
Frequently asked: 254
Mileage: 55,084 km
Time indicator: 0.
Data: 2009.06.30
Time: 19:57:59
02198 - Rear left taillight assembly (M49)
Frozen frame:
Stan bƂąd: 01100100
Priority level: 3.
Mileage: 55,084 km
Time indicator: 0.
Data: 2009.06.30
Time: 19:58:00
01505 - Turn signal lamp; rear right (Micon_cool.gif.
Frozen frame:
Stan bƂąd: 01100100
Priority level: 3.
Mileage: 55,084 km
Time indicator: 0.
Data: 2009.06.30
Time: 20:03:27
02199 - Rear right tail light 2 (M50)
Frozen frame:
Stan bƂąd: 01100100
Priority level: 3.
Mileage: 55,084 km
Time indicator: 0.
Data: 2009.06.30
Time: 20:03:28
01134 - Siren alarm (H12)
012 - Fault in the electrical circuit.
Frozen frame:
Stan be like: 01101100.
Priority level: 3.
Mileage: 56,079 km
Time indicator: 0.
Data: 2009.07.06
Time: 21:54:25
Address 47: System.nagƂaszaniczący File label: 4E0-910-223.lbl
Software part number: 4E0 910 223 K
Hardware part number: 4E0 035 223 A
Component: DSP Amplifier - High, Part Number: H13 0440.
Verification: PROD_01
Serial number: 00000000004043
Encoding: 0000016
Found 1 item:
01044 - Incorrectly encoded steering wheel.
000 - - - Sporadic
Frozen frame:
Stan bƂąd: 00100000
Priority level: 7.
I often think: 1.
Mileage: 65592 km
Time indicator: 0.
Data: 2009.12.16
Time: 16:02:21
Address 4F: Centr.z.elektr.II File label: None.
Software part number: 4E0 910 280 A
Hardware part number: 4E0 907 280 A
Component: ILM Passenger Side H10 0070
Verification: Serial number: 00000000071895
Encoding: 0010111
Part number: 4E0 910 511 A
Component: UGDO HL US H02 0030
Address 52: Electric doors, passenger side.
File label: None.
SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Door control. BF BRM003 0100
Encoding: 0032364
Address 53: Parking brake
File label: 4E0-910-801.lbl
SW: 4E0 910 801 C
HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Verification: A32C0220
Encoding: 0000532
Service code: WSC 25161 444 59310
Found 1 item:
02596 - Brake pads for rear axle.
008 - Unintelligible signal.
Frozen frame:
Stan be like: 01111000.
Priority level: 6.
I often think: 1.
Time indicator: 0.
Frozen frame:
Voltage: 10.77 V
Counting: 61
Address 55: Xenon headlights
Label file: 4F0-910-357.lbl
SW: 4F0 910 357 C
HW: 4F0 907 357 C
Component: AFS 1 H01 0030
Verification: 00000001 Serial number:
Encoding: 0000018
Part number: 4F0 941 329 B
Component: AFS module, left side, H02 0020.
Component: AFS module, right side, H02 0020.
Address 56: Radio
File label: 4E0-910-541.lbl
SW: 4E0 910 541 F HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0480
Verification: 00000000 Serial number: 396JT057530072
Encoding: 0000002
Address 61: Battery Regulator
Label file: 4E0-910-181.lbl
SW: 4E0 910 181 C
HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Verification: 00000000 Serial number: 00000000004059
Service code: WSC 02707 444 53484
Component: from
Encoding: 0000000000000000000000000000000
Found 1 item:
02277 - Relaxation area, level 6.
000 - - - Sporadic
Frozen frame:
Stan bƂąd: 00100000
Priority level: 7.
I often think: 1.
Mileage: 54952 km
Time indicator: 0.
Data: 2008.11.05
Time: 00:43:46
Address 62: Rear left door. File label: 4E0-910-802.lbl
SW: 4E0 910 802 A
HW: 4E0 959 801 C
Component: Door control unit. HL BRM003 0100.
Encoding: 0032364
Address 65: Control unit after start-up.
File label: 4E0-910-273.lbl
SW: 4E0 910 273
HW: 4E0 907 273
Component: Tire Pressure 2 H01
Verification: 00010028 Serial number: 00000900034410
Encoding: 0232125
Found 1 item:
02214 - Tire pressure warning.
000 - - - Sporadic
Frozen frame:
Stan bƂąd: 00100000
Priority: 1
I often think: 10.
Wew.licznik bƂęów: 225
(This appears to be a Polish term, so I'm leaving it as is.)
Mileage: 65542 km
Time indicator: 0.
Data: 2009.12.03
Time: 11:11:16
Frozen frame:
Speed: 0.0 km/h
Temperature: 8.0°C
Kod bƂędu: 3840
Pressure: 2.42 bar
Pressure: 2.35 bar
Pressure: 2.32 bar
Pressure: 2.27 bar
Address 67: Steering wheel. File label: 4E0-910-75x-67.lbl
SW: 4E0 910 754 J HW: 4E0 035 753 A
Component: SDS 3501 US H45 0600
Verification: 00000000 Serial number: 00000510120325
Service code: WSC 12336 024 394758
Address 72: Rear right door. File label: 4E0-910-802.lbl
SW: 4E0 910 802 A
HW: 4E0 959 802 C
Component: Door control. HR BRM003 0100
Encoding: 0032364
Address 76: Parking Assist
Label file: 4E0-910-283.lbl
SW: 4E0 910 283 C
HW: 4E0 919 283 C
Component: Parking Assist System, 8-Channel, H12 0030.
Verification: 00H12000 Serial number: 08720528501166
Encoding: 0201108
Found 1 item:
01627 - Parking assistance system sensor; front right center (G253)
Frozen frame:
Stan bƂąd: 01100100
Priority level: 3.
I often think: 1.
Wew.licznik bƂęów: 168
Mileage: 57,314 km
Time indicator: 0.
Data: 2009.07.15
Time: 14:54:50
Address 77: Telephone
File label: 4E0-910-336.lbl
SW: 4F0 910 336 B
HW: 4E0 862 335
Component: Mobile phone preamplifier H11 0440.
Verification: 00000000 Serial number: 00000007520616
Encoding: 0010900
End.
Translated on 10-09-2026, 1:57.
mullemaus
Post26-12-2009, 22:10    Subject: Audi A8: Recode US Headlights (2005) Quote
I'm not going to do that. icon_wink.gif But, LED taillights? Standard ones? Not all of them support reprogramming. In some cases, the only solution is to replace them with the German equivalent. icon_wink.gif
Translated on 10-09-2026, 1:58.
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Recode Audi A6 4G GRA to 1 km/h Electrical Systems, Vehicle Electronics, Multimedia
No new posts Recode engine control unit On-Board Diagnostics (OBD)
No new posts Recode ECU: How to Reprogram Car Computer On-Board Diagnostics (OBD)
No new posts TDI ECU Reprogramming: Fix Warm Start Issues On-Board Diagnostics (OBD)
