Properly tightening the KW central screw in the AKE?
Go to page: 1, 2  Next
Post07-01-2010, 9:31    Subject: Properly tightening the KW central screw in the AKE? Quote
Hello
Since I need to convert the crankshaft in an AKE, here's my question:
The central screw of the crankshaft gets 200Nm + 180°
The ZMS screws should be tightened to 60Nm + 90°.
How should I secure the crankshaft? While I have the timing tool for changing the timing belt, it never seems to hold properly. icon_question.gif
Does anyone happen to know how it should be done according to Audi's specifications/RLF?
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post07-01-2010, 9:48    Subject: Properly tightening the KW central screw in the AKE? Quote
ZMS with gearbox screw and screwdriver block - 2. Man?
A central screw has a holder with a very large pipe in the shock absorber. At least, I welded one like that for the AAB T4.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Post07-01-2010, 9:55    Subject: Properly tightening the KW central screw in the AKE? Quote
Vibration dampers, there's a really thick one on the T4, right. However, this is not the case with AKE.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post07-01-2010, 10:04    Subject: Properly tightening the KW central screw in the AKE? Quote
Then I can only imagine the interlocking mechanism as a countermeasure, I already saw a metal part with teeth and a hole for the screw.
A better strategy would be to counter the force where it originates. The KW will definitely handle the 450 Nm!
Post07-01-2010, 10:43    Subject: Properly tightening the KW central screw in the AKE? Quote
teileklaus wrote:
Then I can only imagine the "trigger interlocking" as a countermeasure, as I have already seen a metal part with teeth and a hole for the screw.
Sounds good. Do you happen to have an address or phone number for?
teileklaus wrote:
But the KW will definitely handle 450 NM!
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post07-01-2010, 12:34    Subject: Properly tightening the KW central screw in the AKE? Quote
Don't use a number, I'll go to my friendly mechanic and he'll give me and I'll give him and that's it, it's not worth buying for one time.
1,50 m x 50kg equates to approximately 750 Nm icon_eek.gif, so that's good.
Post07-01-2010, 13:53    Subject: Properly tightening the KW central screw in the AKE? Quote
teileklaus wrote:
It's not worth buying for just once.
I don't want to either. DIY (or having someone else do it), but I'd really like to see it first, at least a picture.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post07-01-2010, 14:17    Subject: Properly tightening the KW central screw in the AKE? Quote
Sauer 608 8760 or 608 8770, but there is no MBK listed
Post07-01-2010, 16:41    Subject: Properly tightening the KW central screw in the AKE? Quote
Thank you. Shouldn't be a problem for Grobschmied around the corner. icon_wink.gif
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post07-01-2010, 22:31    Subject: Properly tightening the KW central screw in the AKE? Quote
The engine has been removed
Don't mess it up and reassemble the engine properly to securely fasten the screw.
It won't work if the engine isn't secure.
reflexsilber met.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post07-01-2010, 22:39    Subject: Properly tightening the KW central screw in the AKE? Quote
Okay, I will complete everything, install the engine, and then tighten it securely, if necessary, using a torque wrench beforehand, and then re-tighten it by 180 * degrees after installation.
Post07-01-2010, 23:13    Subject: Properly tightening the KW central screw in the AKE? Quote
Okay, but I will tighten the screws from the ZMS first. Is in good condition when the gearbox is attached, otherwise it's always bad. icon_wink.gif
@RedViewing profile: Red: You nasty little brat, you ruined our monologue. icon_lol.gif icon_lol.gif icon_lol.gif
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post07-01-2010, 23:23    Subject: Properly tightening the KW central screw in the AKE? Quote
icon_biggrin.gif However, it's best to do it properly, what good is your engine if you injure yourself while tightening it?
Post07-01-2010, 23:26    Subject: Properly tightening the KW central screw in the AKE? Quote
teileklaus wrote:
But in your best interest, what good is your engine if you get something bad going on with your body? icon_biggrin.gif
christians
Post08-01-2010, 12:35    Subject: Properly tightening the KW central screw in the AKE? Quote
The repair guide also identifies the fixing screw as a locking mechanism.
450 NM is no problem for the KW, a tuned AKE can easily handle that, which means the KW can withstand significantly more under static conditions.
Gruß Christian
Post08-01-2010, 12:37    Subject: Properly tightening the KW central screw in the AKE? Quote
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Oil consumption in 2.0 TSI engines: A break-in issue? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Audi 80: Replace Crankshaft Position Sensor? Diesel Engine Technology
No new posts Torque Wrench 27Nm: Troubleshooting Noise Issues Transmission, Chassis, Body & Interior
No new posts VP37 Cable Screw: Alternative to Hex Head Screw Diesel Engine Technology
No new posts Golf 4 TDI: Strange Noise When Engine Stops Diesel Engine Technology
