Take a look at the boost pressure of a regenerating BLS (Battery Load Simulator) when you give it gas while it's stationary (this noticeable peak in the middle - I still can't use Excel 2007 properly).
Why is he so inflexible when it comes to the boost pressure?
Possibly, a forced regulation would be perfect for leak testing while the system is stationary.
BLS, very high charging pressure during regeneration
File size:
29.37 KB
Viewed:
1075 times
