cksIT Blaumann
Joined: 05/22/2004 Posts: 399 Karma: +18 / -0 Location: Riedstadt
25-11-2014, 14:32 Subject: Q7 3.0 TDI: Regeneration Problems & Solutions |
Hello everyone,
I'm currently having a small problem. To flush the DPF, you need to perform a regeneration process beforehand.
Unfortunately, I currently have a Q7 here that has only been moved from parking spot to parking spot for the past few months, and it's now displaying an error message indicating that it can no longer regenerate, because the filter is full (with soot, not ash).
Unfortunately, I don't have access to an oven that gets hot enough to properly fire it.
Can the filter also be cleaned by burning it with a gas burner? Has anyone ever tried something like that?
Or, does anyone have any ideas where I could find such an oven in the Rhine-Main area?
Sure, here's the translation:
"Thank you in advance!"
Christian. Man muss es nicht brauchen, aber man muss es haben!
Translated on 17-10-2026, 6:18.
Joined: 04/12/2002 Posts: 18142 Karma: +807 / -0 Location: St.Gallen 2018 Volkswagen T6
25-11-2014, 15:13 Subject: Q7 3.0 TDI: Regeneration Problems & Solutions |
Hello Christian,
You can also find companies online that offer deglazing and rinsing as a service.
If the filter needs to be "pre-fired" anyway, this is a good option.
Translated on 17-10-2026, 6:20.
Profile PM WWW Garage |
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
25-11-2014, 23:04 Subject: Q7 3.0 TDI: Regeneration Problems & Solutions |
Is there a way to force a regeneration on a Q7 using VCDS?
How much ash is already in the filter?
While this may not necessarily apply to the Q7, it shows how it works: https://community.dieselschrauber.org/en/viewtopic.php?t=17091LG, Onkel BM
26-11-2014, 8:56 Subject: Q7 3.0 TDI: Regeneration Problems & Solutions |
Quote: | | Is there a way to force a regeneration using VCDS on the Q7? |
However, even in that case, the load must not exceed a certain maximum value... otherwise, it will get too hot during the regeneration process.
Translated on 17-10-2026, 6:21.
cksIT Blaumann
26-11-2014, 13:33 Subject: Q7 3.0 TDI: Regeneration Problems & Solutions |
Okay. I initiated the forced regeneration, but it stops after a few minutes because the filter is too full (soot, not ash).
I need to check the ash content, but with 250,000 km on it, it's likely to be at the higher end of the range.
I was just thinking about trying it with a gas flame. The thing should be able to withstand heat, and if you hold it vertically, it should work. (No flame directly on the filter, just in the tube).
I would be satisfied if it just improved enough to be reinstalled and regenerated.
A company would simply heat the filter (using an oven, for example).
Thank you very much in advance! Man muss es nicht brauchen, aber man muss es haben!
Translated on 17-10-2026, 6:22.
26-11-2014, 13:53 Subject: Q7 3.0 TDI: Regeneration Problems & Solutions |
Quote: | | I was just thinking about whether I should try it with the gas flame. |
You have nothing to lose. If it gets too hot, simply stop the air supply (burner/compressed air).
If it doesn't work or doesn't get hot enough, you can still give the filter away.
Translated on 17-10-2026, 6:23.
cksIT Blaumann
26-11-2014, 14:11 Subject: Q7 3.0 TDI: Regeneration Problems & Solutions |
To be honest, my main concern was whether this would generate too much heat, or if I was making a mistake in my thinking.
Because burning with a flame costs almost nothing. (The gas costs are likely cheaper than the diesel costs for regeneration  ).
I'll try it and let you know.
Thank you very much! Man muss es nicht brauchen, aber man muss es haben!
Translated on 17-10-2026, 6:24.
26-11-2014, 14:19 Subject: Q7 3.0 TDI: Regeneration Problems & Solutions |
The carbon that burns in the DPF generates a lot of heat, which is great because: without combustion air, the reaction quickly comes to a standstill and is therefore easily controllable.
It would be a shame if you blew too hard and the ceramic or casing melted... then you would have to throw the thing away.
Translated on 17-10-2026, 6:25.
cksIT Blaumann
26-11-2014, 14:34 Subject: Q7 3.0 TDI: Regeneration Problems & Solutions |
"No, I won't blow air into it initially (maybe in a second step), but I'll just use the flame. Since the chimney effect draws the warm air upwards, enough oxygen should be drawn in along with the flame." Man muss es nicht brauchen, aber man muss es haben!
Translated on 17-10-2026, 6:26.
cksIT Blaumann
02-12-2014, 11:14 Subject: Q7 3.0 TDI: Regeneration Problems & Solutions |
Thank you for the answers!
The Q7 is being returned due to further defects, so I can no longer conduct the test.
If I ever have another one with a clogged filter, I will report it here.  Man muss es nicht brauchen, aber man muss es haben!
02-12-2014, 12:15 Subject: Q7 3.0 TDI: Regeneration Problems & Solutions |
Okay, let's wrap things up here for now. Still, thank you for the feedback  . LG, Onkel BM
Translated on 17-10-2026, 6:27.
