Good morning!
I hope that, despite Father's Day, a few people will be able to help me
Currently, I'm having a problem where my Passat TDI (engine code: AKN) is not running, and the cause is still unknown. I would like to inspect the PSG (Powertrain Control Module) from the inside to see if the well-known defect is present and if the bonding connection has come loose.
However, I'm a little apprehensive about removing the lid. From what I've read, you should cut around the edge once (like you would with a stuck lid) and then screw in 2 screws into the holes.
So far, so good. I've managed to screw in two screws. However, when I pull on it, the lid unfortunately doesn't come off; instead, the screws come loose.
Or should the screws be tightened so far that the device lifts off on its own? At first glance, this seems illogical because the holes at the bottom are closed.
So, the question is: What's the best way to do it?
Thank you in advance, everyone!
Best regards, Marcus.
