A3 Rear Brake Caliper Reset: How-To Guide
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post03-12-2002, 9:46    Subject: A3 Rear Brake Caliper Reset: How-To Guide Quote
Hey guys!!!
Okay, here's a question. Does anyone know how to retract the rear brake pistons on an A3 when you're installing new brake pads? The workshop wants to charge me 80 euros for something I've always done myself. And the Hazet retraction tool costs 150 euros. But I don't want to pay even more than the 50 euros for the pads.
Okay, here's the translation:
So please post quickly because I'm already icon_cry.gif javascript:emoticon('}')
Best regards, Sevi!
Translated on 19-09-2026, 5:06.
haehnlein
Post04-12-2002, 16:39    Subject: A3 Rear Brake Caliper Reset: How-To Guide Quote
Hi!
Okay, so I placed a suitable shim on the piston and, using a lever, I pushed the part back while applying constant pressure and rotational movements (I believe clockwise). The rotational movements are important for adjusting the handbrake!
Best regards, Christian.
Translated on 19-09-2026, 5:07.
Tagessuppe
Post04-12-2002, 17:29    Subject: A3 Rear Brake Caliper Reset: How-To Guide Quote
Thanks for the tip, but I ended up taking it to the workshop yesterday. It cost me 214 euros, including the brake discs.
Next time, I'll try it the way you suggested.
"Cu."
This is a short form of the Spanish word "cuerpo," which means "body." It is often used in online communication to refer to a person's physical appearance.
Translated on 19-09-2026, 5:08.
Lanz
Post04-02-2003, 8:56    Subject: A3 Rear Brake Caliper Reset: How-To Guide Quote
I strongly advise against modifying the brakes yourself, if...
1. that the right tool is not available, or
2. lack of practical knowledge.
This brake system design is inherently a weak point in the car and extremely sensitive. When incompetence is added to the mix, the calipers are prone to failure. You'll notice this at the latest during the next vehicle inspection, when the workshop installs brand new calipers.
Best regards, Lanz.
Mc_Givertechnik
2010 Volkswagen T5
Post19-03-2003, 13:43    Subject: A3 Rear Brake Caliper Reset: How-To Guide Quote
Hello!
Yes, yes, this brake caliper has already cost me a lot of time. I always borrow the original tool from a specialized company. icon_question.gif But be careful icon_question.gif: icon_idea.gif Please do not experiment with pliers or other objects on the brake caliper. If the rubber boot is even slightly damaged, the brake caliper will eventually break. Also, some people have accidentally gotten dirt under the rubber boot when retracting it, which can also lead to significant damage to the brake caliper icon_idea.gif. icon_wink.gif So, it's better to invest a little and have a functioning brake with a warranty icon_wink.gif.
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
Translated on 19-09-2026, 5:10.
christians
Post19-03-2003, 21:17    Subject: A3 Rear Brake Caliper Reset: How-To Guide Quote
"So, if a material of lower quality than that used in the Audi 100 is used (they look the same externally), you can definitely handle them roughly because they're not going to last long anyway. In my case, the handbrake mechanism regularly seizes up. I've had to replace 3 calipers in 5 years."
Gruß Christian
Translated on 19-09-2026, 5:11.
No new posts Retracting Brake Pistons: How-To Guide Transmission, Chassis, Body & Interior
No new posts How to reset the service indicator on an Audi A3? Diesel Engine Technology
No new posts Passat 35i: Replace Rear Brake Discs Transmission, Chassis, Body & Interior
