Golf 1J1587: Haldex Control Unit Problems (Solution)
Michael II
Post07-03-2003, 10:54    Subject: Golf 1J1587: Haldex Control Unit Problems Quote
In some cases, the control unit of the Haldex clutch sends an incorrect message to the CAN bus when the ignition is turned on. This message is interpreted by the instrument cluster as "low engine oil level." In this case, the engine oil level warning light illuminates unnecessarily.
Cause.
Software bug.
Solution:
In case of a complaint, please replace the control unit for the Haldex clutch.
Part No. 02D 900 554C; Software version 0010 or higher.
After that, the error memory must be cleared.
Tschüss
Michael II
Translated on 09-09-2026, 9:08.
Ratings - Golf 1J1587: Haldex Control Unit Problems
No new posts Document Golf 1J1587, Transmission Console Mounting Not R... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 Problems: Tailgate/Rear Door Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 5, Problems with windshield washer/water system Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Haldex Öl alles 30 tkm wechseln warum ? Transmission, Chassis, Body & Interior
No new posts ESP Problems VW Golf 4 Transmission, Chassis, Body & Interior
No new posts Golf 3 AHU - Problems with Turbocharger Pressure Control On-Board Diagnostics (OBD)
No new posts Cruise Control Problems Volkswagen Golf IV Transmission, Chassis, Body & Interior
