Retrofitting a freehub to a Lima hub
Go to page: 1, 2, 3, 4  Next
Post25-08-2004, 9:00    Subject: Retrofitting a freehub to a Lima hub Quote
Hi.
The 1Z doesn't have it, but the AFN does - referring to the automatic tensioner on the timing chain.
Has anyone ever retrofitted this before? There's a Volkswagen instruction that recommends retrofitting the 1Z if there's noise in the range of 1200-1500 RPM.
Have you noticed any changes after the renovation?
"Thank you."
Translated on 15-07-2026, 19:10.
Georg-TDI
Post25-08-2004, 9:26    Subject: Retrofitting a freehub to a Lima hub Quote
Hi Martin,
I'm also very interested in this. I constantly struggle with these vibrations within the aforementioned RPM range. I have described my problem in detail here before.
'For me, only replacing the tensioner and flat belt brings some peace, but only for a short time. After about six months, the tensioner is loose again, and the tension pulley starts exhibiting large oscillations.'
Since I drive an automatic car, it's particularly unpleasant for me in the city, as I constantly find myself in the 1200-1800 RPM range. That's when I hear this annoying buzzing sound and even feel noticeable vibrations in the cockpit.
So far, no one I know has reported on a possible retrofit option!
They admit that it was a design flaw, but there's a possibility of eliminating this problem by replacing the spring element and belt. I've had to do this three times now, and eventually, the money invested just becomes too much for me. Retrofitting with a freewheel would definitely be worth it if it makes a difference!
So, we're looking for people to share their experiences...
Best regards, Georg.
Translated on 15-07-2026, 19:13.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post25-08-2004, 17:53    Subject: Retrofitting a freehub to a Lima hub Quote
The replacement alternator that is available cannot be connected to a standard alternator.
B.Eng (FH) u. KFZ Meister
Translated on 15-07-2026, 19:15.
Post25-08-2004, 19:52    Subject: Retrofitting a freehub to a Lima hub Quote
Regarding ease of installation:
Here's something I received from a colleague:
1.9L diesel engine.
AAZ, AEY, AFN, AHU, 1Y, 1Z
Serpentine belt noise within the RPM range.
900 revolutions per minute up to approximately 1,200 revolutions per minute.
______________________________________________
Cause: Due to strong dynamic movements of the ribbed belt, it can occur in the...
In unfavorable cases, this can lead to noise and subsequently to cracks in the wedge.
Rib belt tensioners are coming.
Series: Various measures are being implemented.
KD: Is a noise complaint related to the ribbed V-belt drive?
If this is confirmed, the following steps should be taken:
Bring the motor to the RPM range where the noise occurs.
Then, use a 5mm Allen key to loosen the mounting screw.
Press the tension lever towards the "tighten" direction.
Is the noise being altered or eliminated as a result?
The function of the span element should be checked as follows:
Remove the spring element and secure it in a vise, ensuring the square section is properly aligned.
Insert the 3/4 inch ratchet into the two-pronged opening of the clamping element.
zen and rotate by 60 degrees in the direction of suspension travel. If a hook is...
"Insufficient or no suspension travel detected; replace the spring."
Make sure the suspension travel is correct, then reinstall the spring.
In cases of persistent complaints, the rigid pulley from...
to remove the generator and replace it with a corresponding freewheel belt system.
replace the pulley (see ET catalog). The freewheeling pulley...
It can only be mounted on the Bosch generator. Please refer to the following instructions for the procedure.
For example, repair manual for Volkswagen Golf/Vento 1992 > Electrical.
Investment.
Translated on 15-07-2026, 19:18.
Rudi
Post26-08-2004, 9:21    Subject: Retrofitting a freehub to a Lima hub Quote
Hi Martin,
The pulley with the freewheel mechanism mentioned in the article has the following number:
028 903 119 AA
and costs almost 100 euros icon_eek.gif.
Best regards, Rudi.
Translated on 15-07-2026, 19:22.
Post26-08-2004, 9:27    Subject: Retrofitting a freehub to a Lima hub Quote
@ Rudi
I know icon_twisted.gif.
But if it all gets better because of that, then it would almost be worth it to me.
Paying €100 just on the off chance seems like a lot to me... that's why I'm asking about experiences with retrofitting.
Translated on 15-07-2026, 19:23.
dieter
Karma: +13 / -0   Thank you, like it!
Post26-08-2004, 10:09    Subject: Retrofitting a freehub to a Lima hub Quote
Hi Martin,
Have you read my comments on that topic?
It was a bit different, sometimes "free range" and sometimes not, but now it's "free range" again, which might be helpful.
Okay, here's the translation:
"By the way, the manufacturer of the clutch is INA, and this part is also available through parts suppliers; I paid around €69 for it. However, there are various different models available. The key differences are the diameter and the distance between the friction surface and the alternator."
Greetings.
"Dieter"
T3 syncro 16 AFN
Translated on 15-07-2026, 19:24.
Post26-08-2004, 10:31    Subject: Retrofitting a freehub to a Lima hub Quote
@Dieter
Hmm, I think I read something about that before, but I don't remember exactly what it was or if it came from you.
Do you have a link?
Sure, no problem. Just provide the text you want me to translate.
Translated on 15-07-2026, 19:25.
dieter
Post26-08-2004, 11:02    Subject: Retrofitting a freehub to a Lima hub Quote
Please provide the part number for "freilauf" and the author is "Dieter." That's essentially all the information I need. If you require the same part as me, I can give you the order number next week. To do so, you'll need to measure the diameter and distance between the belt and the alternator.
Greetings.
d.
T3 syncro 16 AFN
Translated on 15-07-2026, 19:26.
Post26-08-2004, 11:34    Subject: Retrofitting a freehub to a Lima hub Quote
Okay.
You have your own thread, but it was about the cleaning up of the perpetrators' mess.
And you wrote something in the ALH belt thread – I took that as a reason to ask about your experiences with freewheels.
I'm going to remove my LIMA disc and post the data here.
Thank you.
Translated on 15-07-2026, 19:27.
Maciek
Post26-08-2004, 11:44    Subject: Retrofitting a freehub to a Lima hub Quote
I installed an AAZ alternator on my car (it was a really good deal icon_smile.gif). It didn't have a freewheel clutch. This caused the belt to vibrate slightly. I drove to a local alternator specialist, and he installed a new freewheel clutch for 50 euros. Since then, everything has been quiet. You need a special tool for this. It was one of those shops where the master mechanic is also the boss and works on cars himself. It's always better than dealing with someone who just sits behind a desk.
Maciek.
Translated on 15-07-2026, 19:29.
wolfi_b
Post26-08-2004, 11:55    Subject: Retrofitting a freehub to a Lima hub Quote
Can someone explain to me what this "free-roaming" feature is good for?
I already understand that it helps with vibrations.
Is this a freewheel like on a bicycle? But doesn't it only have one direction of rotation, which means it creates a fixed connection, or am I wrong?
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 15-07-2026, 19:30.
Post26-08-2004, 12:23    Subject: Retrofitting a freehub to a Lima hub Quote
@ Wolfi
Please read the link from the company INA.
http://www.ina.de/inaupdate/news/publics/present/fach_pkw_nebenaggregat/fa_pkw_nebenaggregat_de.asp
(I think I found this information before, and it was recently posted by Dieter in the ALH timing belt thread.)
It's well explained in there what the free-range system does.
The engine is accelerated with each ignition and then decelerated again. This causes vibrations.
Once accelerated, it can continue rolling freely until a new working cycle of a cylinder provides additional "force".
Without proper tensioning, it pulls on the tension roller side of the conveyor belt, causing it to flutter.
Translated on 15-07-2026, 19:31.
Autofitti
Post26-08-2004, 18:12    Subject: Light machine clutch Quote
Here is the replacement part number from LUK for the alternator clutch: 535 0001 10. However, it fits very tightly and is rarely successfully replaced without the corresponding special tool and without removing the alternator. Furthermore, in 3 out of 5 cases where the clutch was replaced, the noise was not completely eliminated.
Translated on 15-07-2026, 19:32.
wolfi_b
Post26-08-2004, 20:35    Subject: Retrofitting a freehub to a Lima hub Quote
@GremlinViewing profile: Gremlin
Thank you!!!
There are incredibly large forces at play icon_eek.gif icon_eek.gif.
1993 Audi 80 B4 1Z
Translated on 15-07-2026, 19:33.
To
Post27-08-2004, 19:05    Subject: Retrofitting a freehub to a Lima hub Quote
I also have a link to the Lima free run event:
http://www.luk-as.de/de/produkte/pkw/riementriebkomponente.html
Tobias.
Translated on 15-07-2026, 19:34.
No new posts Generator free wheel defective - slipping Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Freewheel for Lima: Alternative to 1-speed Diesel Engine Technology
No new posts Convert Disc Brakes to Drum Brakes Diesel Engine Technology
No new posts Is Lima's clutch always so difficult to engage? Diesel Engine Technology
No new posts Retrofitting heated seats? Transmission, Chassis, Body & Interior
