Deus Violentia Schrauber
19-10-2010, 19:06 Subject: Can the VP37 distribution body be removed without disassembly? |
Can the distribution body be removed without disassembling the entire pump?
BKD GRF
AHF EBF
mdonau Blaumann
Joined: 01/01/2005 Posts: 248 Karma: +5 / -0 Location: 24939 1988 Audi 80 Premium Support
19-10-2010, 19:49 Subject: Can the VP37 distribution body be removed without disassembly? |
Expansion: yes, installation: no! (at least not without a 99% chance of destroying the pump!)
Passat 3B AFN Syncro, E46 330D, T3 1,7TDI, T3-Syncro TD
Profile PM Garage |
19-10-2010, 19:54 Subject: Can the VP37 distribution body be removed without disassembly? |
Reason? Can I not thread the camshaft, or is there another reason?
BKD GRF
AHF EBF
19-10-2010, 20:27 Subject: Can the VP37 distribution body be removed without disassembly? |
Gravity will make the assembly process quite difficult for you...
Profile PM WWW Garage |
19-10-2010, 21:21 Subject: Can the VP37 distribution body be removed without disassembly? |
Okay, I figured it out by looking at the exploded diagram, thank you!
BKD GRF
AHF EBF
vwSchrauber Profi-Schrauber
20-10-2010, 11:15 Subject: Can the VP37 distribution body be removed without disassembly? |
Except for a few engines, it doesn't work well - I unfortunately know this from experience  .
An exception is, for example, the older Opel Frontera 2.3D model, where the VE (variable valve timing) is mounted vertically instead of being integrated into the distributor.
Tagessuppe Profi-Schrauber
Joined: 11/13/2002 Posts: 1142 Karma: +38 / -0 Location: Wien 2001 Audi A2  Premium Support
20-10-2010, 21:09 Subject: Can the VP37 distribution body be removed without disassembly? |
I did it about 7 times in a row with my AGR.
After the last few times, I didn't even feel scared when starting it up  .
I used some very rancid grease from the year Schnee during the assembly.
to keep the roles in place.
It's a really sticky, gooey mess.
He has been running it problem-free for 60,000 km since that modification (except for the current transmission issue).
Profile PM Garage |
22-10-2010, 18:44 Subject: Can the VP37 distribution body be removed without disassembly? |
Essentially, a diesel-soluble adhesive  .
@vwschrauber: A standing VEP? Awesome! Image?
BKD GRF
AHF EBF
Turbinchen Profi-Schrauber
Joined: 04/10/2008 Posts: 200 Karma: +75 / -0 Location: 95615 Marktredwitz 2014 Audi A4 Avant Support
22-10-2010, 18:56 Subject: Can the VP37 distribution body be removed without disassembly? |
Our MF tractor with a Perkins A6.354 engine also has a vertical Lucas VEP. However, it's a somewhat more robust technology than what's used in passenger cars.
Profile PM Garage |
22-10-2010, 20:20 Subject: Can the VP37 distribution body be removed without disassembly? |
Deus Violentia wrote: | Essentially, a diesel-soluble adhesive .
Correct
Just as surgeons use a wire to stitch something together, which is then dissolved by the body
And what? Are you brave enough to do it?
Profile PM Garage |
23-10-2010, 11:23 Subject: Can the VP37 distribution body be removed without disassembly? |
"@ Tagessuppe: I just wanted to remove the manifold to check for any potential debris... However, I think I'll first purchase a faulty pump and examine the whole thing in a "test run" to see how it's positioned, so that there are no surprises and I'm sure about what I'm doing." The technical article with the exploded diagram for the VP37 distribution body is certainly very helpful, but I'm not one of those people who would take such assemblies apart and then ask here how to put them back together  .
BKD GRF
AHF EBF
