Can the VP37 distribution body be removed without disassembly?
Deus Violentia
Post19-10-2010, 19:06    Subject: Can the VP37 distribution body be removed without disassembly? Quote
Can the distribution body be removed without disassembling the entire pump?
BKD GRF
AHF EBF
mdonau
1988 Audi 80
Post19-10-2010, 19:49    Subject: Can the VP37 distribution body be removed without disassembly? Quote
Expansion: yes, installation: no! (at least not without a 99% chance of destroying the pump!)
Passat 3B AFN Syncro, E46 330D, T3 1,7TDI, T3-Syncro TD
Deus Violentia
Post19-10-2010, 19:54    Subject: Can the VP37 distribution body be removed without disassembly? Quote
Reason? Can I not thread the camshaft, or is there another reason?
BKD GRF
AHF EBF
Post19-10-2010, 20:27    Subject: Can the VP37 distribution body be removed without disassembly? Quote
Gravity will make the assembly process quite difficult for you...
Deus Violentia
Post19-10-2010, 21:21    Subject: Can the VP37 distribution body be removed without disassembly? Quote
Okay, I figured it out by looking at the exploded diagram, thank you!
BKD GRF
AHF EBF
vwSchrauber
Post20-10-2010, 11:15    Subject: Can the VP37 distribution body be removed without disassembly? Quote
Except for a few engines, it doesn't work well - I unfortunately know this from experience icon_sad.gif.
An exception is, for example, the older Opel Frontera 2.3D model, where the VE (variable valve timing) is mounted vertically instead of being integrated into the distributor.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post20-10-2010, 21:09    Subject: Can the VP37 distribution body be removed without disassembly? Quote
I did it about 7 times in a row with my AGR.
After the last few times, I didn't even feel scared when starting it up icon_wink.gif.
I used some very rancid grease from the year Schnee during the assembly.
to keep the roles in place.
It's a really sticky, gooey mess.
He has been running it problem-free for 60,000 km since that modification (except for the current transmission issue).
Deus Violentia
Post22-10-2010, 18:44    Subject: Can the VP37 distribution body be removed without disassembly? Quote
Essentially, a diesel-soluble adhesive icon_biggrin.gif icon_biggrin.gif.
@vwschrauber: A standing VEP? Awesome! Image? icon_cool.gif
BKD GRF
AHF EBF
Turbinchen
Karma: +74 / -0   Thank you, like it!
2014 Audi A4 Avant
Post22-10-2010, 18:56    Subject: Can the VP37 distribution body be removed without disassembly? Quote
Our MF tractor with a Perkins A6.354 engine also has a vertical Lucas VEP. However, it's a somewhat more robust technology than what's used in passenger cars. icon_smile.gif
Tagessuppe
Post22-10-2010, 20:20    Subject: Can the VP37 distribution body be removed without disassembly? Quote
Just as surgeons use a wire to stitch something together, which is then dissolved by the body icon_lol.gif
And what? Are you brave enough to do it?
Deus Violentia
Post23-10-2010, 11:23    Subject: Can the VP37 distribution body be removed without disassembly? Quote
"@ Tagessuppe: I just wanted to remove the manifold to check for any potential debris... However, I think I'll first purchase a faulty pump and examine the whole thing in a "test run" to see how it's positioned, so that there are no surprises and I'm sure about what I'm doing." The technical article with the exploded diagram for the VP37 distribution body is certainly very helpful, but I'm not one of those people who would take such assemblies apart and then ask here how to put them back together icon_lol.gif.
BKD GRF
AHF EBF
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF removal for Passat 3C with BMP engine Troubleshooting & Guides
No new posts Disassembling the metering unit of a VP37 Troubleshooting & Guides
No new posts VP37 manifold conversion Diesel Engine Technology
No new posts Clean AGR Valve Without Removal Diesel Engine Technology
No new posts Clean DPF Without Removal: Easy Guide Diesel Engine Technology
No new posts Intake Valve Cleaning: Remove Carbon Build-up? Diesel Engine Technology
